Author Topic: Anyone use the Fuchs Titan Race Pro S 5w-30??? (ALSO which DSG oil?)  (Read 17498 times)
As the title says really...
Car has had Castrol Edge for the first 2 services but then dealer swapped to Quantum.
Last visit they are now using Shell. Not that it matters really, as I won't be using the stealer this time!
After long deliberation I have decided to go with a local VAG specialist.
He told me that he uses Quantum, but if I want to supply my own oil that would be fine!
So I have read that Fuchs have a great rep for making high end oils.
I saw Oilmans offer on the forum marketplace and wondered if anyone else has opted for the Fuchs Titan Race Pro S?
Also without sounding silly.... Would it be better to keep it running on the Castrol/Quantum oils??? (same stuff, I've read...but not sure)
Here is the Oilmans link...
(do we get a forum discount on top of this price?)
http://www.mk5golfgti.co.uk/forum/index.php/topic,42108.0.html
EDIT: Also what DSG oil should we be using and how much of it? Just wondered if it would be better to buy this at the same time as engine oil, or let the Indy supply this?
Thanks,
Carlo.  :smiley:
« Last Edit: February 13, 2012, 09:03:49 am by monte »
Re: Anyone use the Fuchs Titan Race Pro S 5w-30??? (ALSO which DSG oil?)
« Reply #1 on: February 13, 2012, 09:22:37 am »
Whatever way you choose, don't forget you also need a filter for the dsg oil change...
« Reply #2 on: February 13, 2012, 09:29:01 am »
Yes mate.  :happy2:
Here is the list on the quote from the Indy...
oil filter 12.40
air filter 18.26
fuel filter 26.16
pollen filter 15.30
spark plugs for 4 55.49
dsg oil 80.57
dsg filter 14.35
washer 0.75
long life Quantum oil 5lt 40.00
sump plug 1.72
Offline richtung
  • -Receive: 56
« Reply #3 on: February 13, 2012, 10:51:15 am »
Yes mate.  :happy2:
oil filter 12.40
air filter 18.26
fuel filter 26.16
pollen filter 15.30
dsg oil 80.57
dsg filter 14.35
washer 0.75
sump plug 1.72
Im sure the spark plugs dont need changing until 60k (unless of course, you have reached 60k)?
I would use the Castrol Edge over the Quantum stuff - you can get it cheap enough from Asda.
Is it due a brake fluid change?
« Reply #4 on: February 13, 2012, 11:00:12 am »
Perhaps take this opportunity to fit an ECS magnetic sump plug purposeful in helping to look after your engine and fairly inexpensive  :happy2:
What Indy you use Carlo?
Offline alexperkins
  • -Receive: 99
« Reply #5 on: February 13, 2012, 01:16:10 pm »
Thats quite expensive for 5Lt of quantum long life 3 - they are making a tidy sum on that!!
20L is only £67 from TPS direct...
As for DSG oil, only use VW OEM oil
TPS is the best bet for getting all the parts to be fair! You'll save a bomb
Offline DJM
  • -Given: 28
« Reply #6 on: February 13, 2012, 02:02:07 pm »
As above TPS is cheap for oil especially if you can get trade.
But the Fuchs Titan Race Pro is good stuff, used it in my old RS. Was going to put it in the golf but ended up getting the proper VW stuff for under £20 from TPS.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: February 13, 2012, 02:28:25 pm »
It's also worth bearing in mind what you'll use to top up.
I work for a large Oil manufacturer and one of our key points of advice to customers is never to mix different brands of Synthetic oils.  Mixing of oils with a Mineral base stock is generally considered to be OK but most definitely not Synthetic.
I'm lead to believe that the Quantum oil is in fact a Castrol product which is branded for VW (it may have a different additive package to other Castrol products). Sometimes if you see a drum of it you'll see the makers label on the drum with the blending details and batch number.
If you look at a product data sheet for Quantum then you'll see the helpline is in Swindon, have a look who else makes oil and has offices and a technical helpline in Swindon  :evilgrin:
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #8 on: February 13, 2012, 02:31:28 pm »
Quantum Longlife is branded BP (at least the last 10 barrels I've bought have been)
Their semi synth offerings are branded Castrol  :happy2:
EDIT: But yes, BP own castrol so its all the same.
« Last Edit: February 13, 2012, 02:37:27 pm by alexperkins »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: February 13, 2012, 02:33:44 pm »
Ok smart arse and which group of companies does Castrol belong to??
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
Offline alexperkins
  • -Receive: 99
« Reply #11 on: February 13, 2012, 02:36:12 pm »
 :notworthy:
Very true Stu very true.
Branding exercise it would appear then.
Offline TagnuT
« Reply #12 on: February 13, 2012, 04:13:25 pm »
Can you walk in off the street and buy things from TPS or do you need an account?
Bye Bye Edition 30.
Offline alexperkins
  • -Receive: 99
« Reply #13 on: February 13, 2012, 04:14:13 pm »
Some TPS's will let you walk in, others will require a trade purchase order
Worth just giving them a call  :happy2:
Offline TagnuT
« Reply #14 on: February 13, 2012, 04:17:43 pm »
Cheers anyone know if the one in Leeds will let you walk in an buy good without an order?
Bye Bye Edition 30.
