Author Topic: mk5 gti stolen without keys obd port :(  (Read 8148 times)
Offline Markyed30
« on: December 09, 2014, 07:36:38 pm »
Seen the video on Facebook so can't post it here watch the video on her Facebook page search her name no need to add her to watch dirty robbin wan*
Also broke in to car next to it on drive and took items from it, hung about for 20 min apparently  :sad1:
Her fb name is :samantha mccullough-spinks
Offline GTi-Andy
Re: mk5 gti stolen without keys obd port :(
« Reply #1 on: December 09, 2014, 08:21:05 pm »
chop the c**nts hands off when they catch him
So much for keeping it standard!
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #2 on: December 09, 2014, 09:01:28 pm »
Was it stolen with the keys?
Hard to tell on the video - but it appears he made short work of the ignition and immob if it wasnt with them!
What a twat
Offline Markyed30
« Reply #3 on: December 09, 2014, 09:19:37 pm »
She said the police mentioned they used a laptop think that's what u see him taking in to the car, thief had no keys
« Reply #4 on: December 09, 2014, 09:48:49 pm »
Isn't this what has been happening to bmw cars?
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #5 on: December 09, 2014, 09:52:53 pm »
Guess this fairly old post covers most of it!
http://www.mk5golfgti.co.uk/forum/index.php/topic,50080.15.html
Never realised it was that easy!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=nsdd6r0gihq0onjquge04mkurd&/topic,90967.msg917089.html#msg917089
« Reply #6 on: December 09, 2014, 10:51:00 pm »
It looks like he has a key to me. Cant really see when he plugs into the OBD port.
05 | Tornado Red | DSG
« Reply #7 on: December 09, 2014, 11:46:32 pm »
You can see the laptop open as he walks to the car then puts it on the passenger seat and then plugs something Into the obd and it starts and he drives off
Offline xjay1337
  • -Receive: 377
« Reply #8 on: December 10, 2014, 01:04:03 am »
Unless I've missed it
at 3.58 in the video he walks up to the car and unlocks it..........
All the lights come on. puddle lights, front/rear the lot... leaving home that is. so I suspect he had a working key but one perhaps that was not coded to the immobilsor?  Perhaps he used one of those frequency catcher thingy-ma-bobs.
Then he fumbles about inside.
Being a pre-2007 car you can easily get tools which can read the cars SKC (immob security code) and reprogram a key or disable the immobilsor alltogether .
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #9 on: December 10, 2014, 05:20:58 am »
The drivers door lock always the weak spot :( He may have visited before got the key number had a key cut then returned with laptop?
Hope it finds it's way home, tempted to de-lock mine
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #10 on: December 10, 2014, 07:54:48 am »
He obviously had a remote fob to get in, and a pre-cut blade (or a selection of blades) at the very least.
The older pin based immos can be quickly and easily bypassed and coded via OBD, on the older platform cars (ME7/EDC15, even EDC16 which covers a lot of the VAG diesels) you can even buy self-contained devices that plug in and remove the immo via OBD2 in no time at all. Didnt find anything for the ME9 TFSI though, but i didn't look very hard
To me that looked far too quick for a proper read/write of the immo data, so perhaps he had something similar or some kind of emulator?
« Last Edit: December 10, 2014, 08:15:59 am by Dan_FR »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: December 10, 2014, 08:43:38 am »
maybe he used a bluetooth device to plug into the OBD and read the immo data , or do you still need ignition on for the OBD port to actually work?
Offline xjay1337
  • -Receive: 377
« Reply #12 on: December 10, 2014, 09:51:45 am »
The OBD port only works with the ignition on.
As I said, and as Dan said also mentioned, he probably had a remote fob already coded to the car's frequency and must have had some sort of pre-cut key.
I suspect there is more to this than meets the eye.
Offline Markyed30
« Reply #13 on: December 10, 2014, 10:22:51 am »
Are you sure because when ur installing bluefin it works when it's telling you to cycle threw ignition on and off when programming
Offline xjay1337
  • -Receive: 377
« Reply #14 on: December 10, 2014, 12:02:54 pm »
use vagcom or vagtacho and try to do anything with the ignition off........
you may need to cycle through ignition to save/reset certain settings this is very normal.
