Author Topic: Running Speaker Cable Through Door  (Read 9007 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=d1380mie4n328uurk9gmqqrh7k&/topic,90967.msg917089.html#msg917089
« on: January 23, 2015, 06:32:14 pm »
Hope this helps someone out. Took a few pics while installing my new speakers.
If i've done anything wrong or missed something please let me know.
What you will need.
  • Trim Removal Tool.
  • Dremel
  • Small Drill Bit
  • Wire Snake/Coat Hanger
Unclip rubber grommet using trim tool. Pry from the top.
Pull down orange leaver this will release the outer connector.
Squeeze the two clips together this will pop out the inner connector.
At the bottom of the block you will see a number of unused pin holes. With your dremel and a small drill bit. You need to drill out two pins.
Have the dremel on low speed.
Drill the two holes out first then drill out the piece in between them.
Single Image
    Clip in the inner connector and feed the wire through.
    Make a small slit on the door side of the grommet and feed through the wire snake.
    Tape wire to snake and pull through.
    The orange clip should close easily. If there is any resistance please remove and reseat.
    05 | Tornado Red | DSG
    Offline dazza
    • -Given: 90
    • -Receive: 190
    • Coding Boffin
    Re: Running Speaker Cable Through Door
    « Reply #1 on: January 23, 2015, 06:34:25 pm »
    @th3_f15t hope this helps mate. The written word is not my strongest point.
    « Reply #2 on: January 23, 2015, 07:55:33 pm »
    Good write up!did the same when I did mine
    Offline th3_f15t
    • -Receive: 183
    « Reply #3 on: January 24, 2015, 08:48:06 am »
    Oh, and where was your guide? :P
    Pictures paint 1000 words, so happy with that! I'll give it a shot one weekend and let you know.
    Offline Softishman
    « Reply #4 on: January 24, 2015, 08:55:39 am »
    A little question... If you going to install a three-way speaker set up with all driven by it's own amp? Then I need 3 cables in, are there room for that many?
    Offline SI-R32
    • -Receive: 126
    « Reply #5 on: January 24, 2015, 09:57:57 am »
    Yes there are mate,  the plug has 28 pins and uses about 10
    Offline dazza
    • -Given: 90
    • -Receive: 190
    • Coding Boffin
    « Reply #6 on: January 24, 2015, 10:05:30 am »
    An active system  :drool:
    With some careful work with the dremel you can get it done these pins next to the ones i drilled out are also free.
    Offline piston broke
    « Reply #7 on: February 03, 2015, 09:44:17 pm »
    Good to know you can get three sets of speaker cables through for a full active door speaker set, what size cables did you use?
    Offline dazza
    • -Given: 90
    • -Receive: 190
    • Coding Boffin
    « Reply #8 on: February 04, 2015, 12:19:09 am »
    16AWG / 6.5mm * 3.2mm
    Offline Softishman
    « Reply #9 on: February 05, 2015, 04:39:28 pm »
    An active system... The components i am using are;
    Blaupunkt Phildalphia 835
    Focal Polyglass 165 VR3 front
    Focal Polyglass 165 VRS back
    DLS Nordica 10" bass
    Audison BitOne processor with DRC control
    DLS A2 For tweeters front
    DLS A4 for mids an bass front
    DLS A2 for backdoors
    DLS A6 for bass
    DLS 1F kondensator for A6
    DLS 0,5F kondensator for A4
    Offline dazza
    • -Given: 90
    • -Receive: 190
    • Coding Boffin
    « Reply #10 on: February 05, 2015, 05:21:05 pm »
    DLS A6 for bass
    Please tell me you are moving the speakers from their stock locations? If so i'd like to see some pics.
    Offline Softishman
    « Reply #11 on: February 06, 2015, 12:10:39 pm »
    Sorry, will use original locations... Want everything to look standard... And because of new house and renovating this build have to wait to next winter....  :sad1:
