Author Topic: Fitting Cruise Controller  (Read 1991 times)
Offline K9
  • VW LifeStyle
« on: March 06, 2015, 03:43:09 pm »
Hey guys.
saw the cruise control how-to here in the how-to selection but do i need to do a steering angle  reset if i only change my currect stalk to one with cruise?
can i install the stalk without taking the computer off?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Fitting Cruise Controller
« Reply #1 on: March 06, 2015, 03:45:25 pm »
you have to take the slipring and steering angle sensor to remove the stalk. As its removed, you will have to reset it.
Offline K9
  • VW LifeStyle
« Reply #2 on: March 06, 2015, 04:03:49 pm »
any how-to to reset it with vcds?
is it hard? easy? and removing the airbag is it only to turn the wheel and insert a screwdriver and push the 2 clips down?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: March 06, 2015, 04:08:40 pm »
This video may help
and also this one I made on how to remove steering wheel
You will need to turn the steering wheel full lock to the left and hold for a few seconds then full lock to the right and hold for a few seconds, then centre the steering wheel and go for a short drive.
Offline K9
  • VW LifeStyle
« Reply #4 on: March 06, 2015, 04:24:08 pm »
the airbag connector is it just to pull it toward you? and the controller need to be removed and dissconnected or can they stay connected and just let it hang loose?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: March 06, 2015, 04:26:47 pm »
the airbag connector has to be removed otherwise the steering wont come off. The wires going into the steering wheel controller can stay connected but the module itself will need to be removed so you can remove the slip ring and angle sensor
Offline K9
  • VW LifeStyle
« Reply #6 on: March 06, 2015, 04:29:05 pm »
great. becouse i dont wana mess with the controller at all. the airbag wire is just to be pulled toward you or do i need to press some kind of clip as in the 2nd video i showed?
edit: any how-to reset the steering angle via vcds?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: March 06, 2015, 04:44:06 pm »
you pull the white clip towards you and then that releases the whole yellow connector from the slip ring.
see above in my previous post below the links I posted how to do the reset  :happy2:
