Author Topic: Dazza Cam Belt DIY Attempt  (Read 8541 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« on: May 18, 2015, 11:12:37 am »
Started stripping everything out to get the engine mount out.
Have a question about putting the car in TDC. The hanes manual shows there should be a mark on the crankshaft pulley but i cant see any marks??
05 | Tornado Red | DSG
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
Re: Dazza Cam Belt DIY Attempt
« Reply #1 on: May 18, 2015, 11:48:12 am »
it's more of a 'nick' on the inner lip
you can set the cam to position then look for the mark on the bottom pulley
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2 on: May 18, 2015, 12:12:48 pm »
Thanks mate found it now. My cam belt cover is one piece so it's not easy to see that top marks either. Can i set it to TDC after jacking it up and removing the engine mount and belt cover?
Offline olethalb
  • -Receive: 31
« Reply #3 on: May 18, 2015, 12:16:14 pm »
there should be an arrow on the belt cover around the 2 o clock position
yes can set to tdc whenever you like as long as you have bottom pulley on (and obviously belt)
« Last Edit: May 18, 2015, 12:20:03 pm by olethalb »
Offline bigmig95
  • -Receive: 50
« Reply #4 on: May 18, 2015, 12:21:54 pm »
Hi Dazza, apparently single piece cambelt cover is a PITA as its trickier to remove on an AXX and some BWA with the single piece cover (been superseded with two piece later on), believe you have to shift the whole engine and box across to remove the cover.  If you plan on keeping the car change to a two piece if possible (if part are cheap enough).  I vaguely remember cambelt changes on my old AXX being priced higher due to the additional labour time involved.  Never done it personally but remember being informed about this on a couple of occasions.  :happy2:
« Last Edit: May 18, 2015, 12:23:27 pm by bigmig95 »
Offline olethalb
  • -Receive: 31
« Reply #5 on: May 18, 2015, 12:24:08 pm »
yea the 1 piece are a pita
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: May 18, 2015, 12:31:06 pm »
I can see the top mark would prefer to have the cover off to make sure its perfect. I have DIY paranoia AGAIN.
So removing the engine mount is not enough to get the cover off?
Offline bigmig95
  • -Receive: 50
« Reply #7 on: May 18, 2015, 12:36:13 pm »
Vaguely recall something about gearbox mount off as well so you can shift the whole engine and box across to remove the cover.  Someone with some practical experience on here should confirm or dismiss this  :smiley:
Offline olethalb
  • -Receive: 31
« Reply #8 on: May 18, 2015, 12:40:16 pm »
you should be able to get it off without moving engine over with he right tools, it's just fiddly work.
Offline olethalb
  • -Receive: 31
« Reply #9 on: May 18, 2015, 12:48:49 pm »
Pic of cover with bolts needed to remove for reference
Offline DANBOY66
  • -Given: 41
« Reply #10 on: May 18, 2015, 01:24:40 pm »
done one the other day on an axx
had to remove the exhaust from the turbo and driveshafts to get the room i did not touch the gearbox mount  :wink:
i was on a 2 post ramp with air tools in a friend's garage he advised me that's what he does on golf's with a one piece cover so i just cracked on and removed it all
Dan..
Dan..
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #11 on: May 18, 2015, 01:29:44 pm »
Thanks guys i will continue with the original plan. Get the mount out.
I can already see a potential problem one of the 6 pulley bolts is nearly rounded completely.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #12 on: May 18, 2015, 04:22:27 pm »
So the bolts are out of the mount. Lifted the engine a bit its also moved back a lot.
Whats the best way to get the mount out. Don't want to push it up anymore.
Just my luck the beater broke down when i went to pick the kids up from school. Wife not impressed having to walk home.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #13 on: May 18, 2015, 07:45:00 pm »
The mount is out.
The cover came out easy getting the mount out of the cover was a bit of a PITA. Just incase any one else has to do it the left hand side of the mount comes out first.
Will be replacing with a two piece cover.
Managed to get the beater going with the help of the Golf battery.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #14 on: May 19, 2015, 12:30:23 am »
Can anyone confirm the torque settings??
Engine mounting
Limiter???
20nm + 90º
Mounting to engine
60nm + 90º
Mounting to body
40nm + 90º
Timing belt idler roller (aren't they both the same size)
Large 40nm
Small 25nm
Timing belt tensioner roller.
Turbo without split cover 23nm
Turbo with split cover 25nm
The Hanes manual i have does not list my engine code so want to double check everything.
