Here we go Scott
Pump for headlight washers - 3B7 955 681 also N903 038 01 this is the O-ring for the pump
Gasket - 431 955 465A
Lift Cylinder - 1K6 955 978A x 2
Speed nuts - n909 591 01 x 4 - 2 per cylinder
Nozzle carrier Left - 1K6 955 103
" " " Right - 1K6 955 104
Cover cap Left - 1K6 955 109 GRU
" " Right - 1K6 955 110 GRU
Adaptor - 1T0 955 665
Connector - 1J0 955 665E x 3
Hose in 10m length - 1J0 955 964F
Angled piece - 1J0 955 665A
Junction - 7L6 955 873
Terminals - 1J0 955 846 x 8
Cable tie with teminal socket - 3D0 971 838E x 1
If i've missed any thing ill add it later
By the way you may need this too, its the water level for the washer bottle.
Water level switch - 7M0 919 376
O ring - 7M0 919 382
Flat contact housing - 7M0 973 202
Darren
