Author Topic: Edition 30 re-map??  (Read 2521 times)
Offline Gooky
Edition 30 re-map??
« on: May 05, 2016, 09:14:59 pm »
Evening Guy's im just reading up on remaps. What would be needed to do a stage1 on ed30 and what are the benefits or is it just best to keep it standard? I'm unsure whether to get 1 and what's the best everyone has used.  :thinking:
Offline Mitch H
  • -Receive: 25
Re: Edition 30 re-map??
« Reply #1 on: May 05, 2016, 09:19:04 pm »
Definately get it mapped. Different car once mapped. Stage 1 should see you just over 300bhp. Niki at rtech is your man for mapping!
If it's manual budget for a clutch if it's dsg then no Probs there.
It's worth opening the cat up and smashing the inners out then welding it back together. Realy cheap mod or free of you DIY it! That should get you another 10-15bhp.
Then after that start saving for an intake system and turbo back exhaust system to go stage 2 ;)
Offline xjay1337
  • -Receive: 377
« Reply #2 on: May 05, 2016, 09:33:58 pm »
Pre-cat delete.
New rev g DV
pcv system sorted.
new filters (intake would be great if not a drop in panel filter)
99 octane fuel... new fuel filter... etc...
usual stuff........
rtech also has a list of map requirements on their website.
Offline Gooky
« Reply #3 on: May 06, 2016, 10:47:44 am »
Thanks Guys ill have a browse on there web site now  :happy2:
« Reply #4 on: May 06, 2016, 12:16:40 pm »
A bone stock ED30 usually sees around 300hp from stage 1, but you might need an aftermarket high pressure pump and clutch.
Adding filters, exhausts, intercoolers etc will start getting you into the bigger numbers.....and consequently much shorter tyre life!
Offline bigeyd
  • -Receive: 31
« Reply #5 on: May 07, 2016, 10:39:47 am »
There is other mappers out there like AMD,APR,Revo you can try
Offline GYG30
« Reply #6 on: May 07, 2016, 12:30:58 pm »
R-tech on mine with pre-cat removed. Very happy with it
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #7 on: May 07, 2016, 05:32:36 pm »
My eddy made 310 with just an induction kit. So not bad.
Charlie23
« Reply #8 on: May 07, 2016, 05:48:34 pm »
Just had mine Re-Maped today. Had Apr stage 1 and the difference is unbelievable. Very happy with it  :happy2:
Offline Madone
  • -Receive: 27
« Reply #9 on: May 10, 2016, 02:09:00 pm »
Revo and APR are the big names worth checking out. You won't be disappointed with either. I actually had a Superchips bluefin at stage 1, it was great as I could flash it back to stock myself for any warranty work (bought the car from a VW dealer). Now it's out of warranty I moved to revo
