Author Topic: Fitting a RCD510 DAB to 2008 MK5 Golf  (Read 2760 times)
abdoujaparov
« on: September 19, 2016, 07:45:34 pm »
Hello there! first post newbie alert....
Recently changed car to a 2008 MK5 GT 170 and am looking at swapping out the headunit for a genuine DAB unit if possible.
Just working out a bit of a shopping list and things to look out for.
I have read that i may need a bluetooth unit if i want to use bluetooth with the RCD510, can anyone confirm?
Reading up on various CAN/ battery drain issues, will the 2008 be affected by this?
So far i believe i need the RCD510 DAB unit and a suitable DAB ariel. Anything else? harnesses etc?
Cheers!
Offline Pashka
Re: Fitting a RCD510 DAB to 2008 MK5 Golf
« Reply #1 on: September 19, 2016, 09:33:17 pm »
You will need fm/am arial adapter and DAB antenna. Your gateway is okay, will not get battery drain. For bluetooth - need to buy the proper kit.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline dronners
« Reply #2 on: September 20, 2016, 12:07:12 am »
i fitted a normal RCD510 into my 2008 without battery drain
abdoujaparov
« Reply #3 on: September 20, 2016, 07:42:08 am »
Thanks, do you know the model number for the proper kit? Or have a link to it?
