Author Topic: Neuspeed rear anti roll bar and neuspeed drop links  (Read 27320 times)
« on: January 19, 2009, 04:44:50 pm »
I bought my neuspeed rear arb from Awesome last year and and it was great for about 6k miles until one day i has a lot of noise coming from the rear end  :sad:, so a trip to the dealer showed it was down to the arb putting to much stress on the oe droplinks and sending noise up the rear shocks  :sad:.
I had Vw take the Neuspeed arb off and i put the stock one back on to find out all the noise had gone  :surprised:, i phoned Andy at awesome to let him know the problem and he said bring the arb in for him to look at to see if it was bent or out of line.I took it over and Andy, me and Jim had a look and it looked fine  :confused: so after having a chat i asked jim what arbs are on there mk5 and he said the same as yours  :rolleye: so i said lets have a look at the droplinks on yours to see how much pressure they are under and after looking he said to me he thought they would not last long if on the hard setting like mine are  :driver: so he very kindly asked me to try the new neuspeed droplinks to see if this is the prob and the cure
some quick pics of the install
VW droplinks and stock arb
unbolt the stock arb clamps 2 bolt per clamp
and undo the droplinks on the ard and on the arm
and then slide the arb out
you need to keep the arb clamp bolts and the droplink nuts and change the clamp over to the neuspeed arb and put lots of grease on the new poly bushes
and then put the bar back on
and then fit these bad boys   :drool:
the little spacers slide on the bolts 1 on the the top between the bolt and the arm and the bottom one goes between the arb and the droplink  :happy2:
they have been on 2 days now and they have stopped all noise and have made the back stiffer on the corners  :driver:
big thanks to awesome for sorting these out for me (free) as they need to know if there is a problem with the arbs and i will be keeping an eye on them over the next few months
« Last Edit: January 19, 2009, 05:07:39 pm by MAT ED30 »
matt a
Re: Neuspeed rear anti roll bar and neuspeed drop links
« Reply #1 on: January 19, 2009, 06:21:41 pm »
Nice looking drop links.  :happy2:
« Reply #2 on: January 19, 2009, 06:35:40 pm »
Great write-up Mat.  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: January 19, 2009, 06:43:59 pm »
circlip retained bearing ARB links  :drool: awesome kit too nice to go under the car  :grin:
nice write up Matt  :happy2: and an interesting solution to a wierd problem
Red ED35 5dr DSG
BLOG | BUILD
« Reply #4 on: January 19, 2009, 06:46:58 pm »
they are as nice as the walk kit  8)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: January 19, 2009, 08:43:59 pm »
Very good write up Mat, thanks for taking the time to do this  :happy2:
« Reply #6 on: January 19, 2009, 09:22:17 pm »
mat, whats the pros/cons to this kit as a pose to getting the eibach? im thinking of getting eibach front and back at awesome on wednesday
« Reply #7 on: January 19, 2009, 09:27:58 pm »
i think the neuspeed one is thicker and is adjustable ie 2 settings ie normal road use or race setup so stiffer  :happy2: if you are doing the back i would get the droplinks they are stunning bits of kit  :drool:
« Reply #8 on: January 19, 2009, 09:46:31 pm »
I'm not convinced about the Neuspeed droplinks - They certainly look strong but VWR have done goodness knows how many hard racing miles on the oem droplinks on lots of VW cars and never had a problem. With V3 coilovers I'm not sure I need a stiffer rear end.
I'm just not very confident about Neuspeed products - They seem to be good at producing good-looking gear that's not needed - I'm particularly referring to that rear triple boot strut thingy. The Turbo Discharge and Charge pipes I bought by them, following Awesome's advice, have had no measurable performance gains.
Just my current opinion.
« Reply #9 on: January 19, 2009, 10:00:39 pm »
the thing with vwr is most of there cars are on the track and are very well looked after but mine has done 10k on the neuspeed arb and it was just too much for the vw droplinks on hard setting  :rolleye: most companies bring out lots of cheap crap that they claim do things that they dont and u need to make your own mind up as to what is good for u. I am more than happy with neuspeed and Awesome gti for there help with the problem and will test these out over the next year on the road and on the track so they will get some stick and if they are going to brake i am sure i will find out  :happy2:
« Last Edit: January 19, 2009, 10:07:37 pm by MAT ED30 »
« Reply #10 on: January 19, 2009, 10:01:42 pm »
that boot strut did completely send me running from neuspeed stuff to be honest, but im still keeping an open mind. ill speak to awesome tomorrow, see what the say and de-cipher the sales pitch
Offline gazbutS3
« Reply #11 on: January 19, 2009, 10:24:16 pm »
alot of its down to cost also Jay, if I remember correctly the front and rear eibach roll bars are not much more than 1 neuspeed roll bar, they may be better but not twice as good
« Reply #12 on: January 19, 2009, 10:26:43 pm »
....True, and you are right to do what you're doing. Being "very well looked after" means that everything is regularly inspected and serviced as appropriate, so they'd spot a droplink problem.
I've had Eibach (non-adjustable) ARB's on for about 50k miles and had to regrease the bushes and replace a broken mount, but no probs with my oem droplinks.
:drinking:
« Reply #13 on: January 19, 2009, 10:28:20 pm »
....And the Eibach ARB's aren't so inferior that they warranted changing to match my new VWR suspension.
:driver:
Offline gazbutS3
« Reply #14 on: January 19, 2009, 10:34:48 pm »
the Eibachs do have two settings don't they, I'm sure they had 2 sets of mounting holes for the drop links when I had them on the ED30, I could be wrong though :smiley:
