Author Topic: fitting Passat switches to Mk5 golf  (Read 71287 times)
Offline 182_blue
  • -Receive: 54
« on: January 31, 2009, 11:54:35 am »
I just thought i would post a little guide of how to fit the Passat parts with extra chrome bits , it may also help those who wish to fix faulty parts too, i bought the set from eBay and used the panel tools that i have had a while, if you require any help just ask (ps i accept no responsibility if you damage anything whilst dismantling your own car)
The tools i use
The parts
Light switch,
use this guide (as posted by Very Cherry)
–   Switch off ignition and all electrical consumers.
–   Turn rotary grip of light switch to position “0”.
–   Push in rotary grip of light switch -1- and turn it clockwise slightly -2-.
–   Hold grip in this position and pull light switch out of dash panel using grip -3-.
Disconnect connector -arrow-
Installing
–   Fit connector to light switch. (as above)
–   Hold light switch and press rotary part of light switch firmly inwards -1- and turn slightly to right -2-.
–   Hold grip in this position and insert light switch in dash panel -3-.
–   Turn grip of light switch to position “0”, release and engage switch.
simple really, just hope it isnt locked in like mine was, then simply remove the plug and put new one in and slide it into place
Drivers handle
I pulled it from the front, you will see the two clips on the right hand side, when these are free you will then need to free the two metal clips at the bottom of the handle near the back, these are a little harder to remove but a little pressure and they come out, dont pull to hard as the handle is held in by 3 plastic pop in bits, again gentle pressure and they soon come out, then its simply removing the old switches by pushing a flat blade under the clips and the old electric unit pops out, pull out electrics and instal new unit, then re fit electrics and pop handle back on
passengers handle
For these you remove the bottom part of the handle, start at the back of the handle (as in picture), and pop the handle out, the handle is then held in via two metal clips and a plastic pop clip right at the top, the handle pulls directly out from the door, do not pull up or down etc, just pull it directly outwards , then you can see the switch, i again removed the switch by prying it out with a flat device, when out pop off electrics put in new unit, put electrics back in and renistall the unit, handle pops back on and jobs done (well, after you do the other two handles)
And all done
« Last Edit: February 10, 2009, 08:04:40 am by 182_blue »
Re: fitting Passat switches to Mk5 golf
« Reply #1 on: January 31, 2009, 12:51:00 pm »
very thorough Shaun Excellent stuff.  :drinking:
« Reply #2 on: January 31, 2009, 01:22:36 pm »
Nice one Shaun  :happy2:
I take it mine will be a bit cheaper as mine is a three door?
Can you PM me the E-bay seller details please mate?
« Reply #3 on: January 31, 2009, 01:26:12 pm »
I should have all the technical drawings for the removal of the other bits if you want me to post them up?
Offline 182_blue
  • -Receive: 54
« Reply #4 on: January 31, 2009, 01:38:00 pm »
yeh, why not  :happy2:
« Reply #5 on: January 31, 2009, 01:57:49 pm »
Here you go mate:
Removing and installing switch module for driver side window lift
Special tools and workshop equipment required
-   Removal wedge -VAS 3409-
NoteWhen removing and installing components that are in view (switches, covers, trim and so on), mask off areas in which tools (wedge -VAS 3409-, screwdriver) are used to prise out those components using commercially available adhesive tape.
The following components are integrated into the driver side window lifter switch module on 4-door vehicles:
- Front left window regulator switch -E40-
- Rear left window regulator switch in driver door -E53-
- Rear right window regulator switch in driver door -E55-
- Front right window regulator switch in driver door -E81-
- Childproof lock button -E318-
- Button illumination bulb -L76-
Note The above mentioned components cannot be replaced individually.
The following components are integrated into the driver side window lifter switch module on 2-door vehicles:
Removing
–   Use the removal wedge -VAS 3409- or a screwdriver to carefully prise the mounting frame out of the door trim -arrow-.
–   Separate connectors -arrows-.
–   Release locking lugs -arrows- and remove switch from installation frame.
Installing
Install in reverse order of removal.
« Reply #6 on: January 31, 2009, 02:52:48 pm »
Removing and installing fuel tank flap release button -E319-
NoteThe fuel tank flap release button -E319- features integral button illumination -L76-, which must not be replaced individually.
Removing
–   Remove door trim → Rep. Gr.70.
–   Disconnect connector -arrow-.
–   Release locking lugs -arrows- and remove switch from door trim.
Installing
Offline 182_blue
  • -Receive: 54
« Reply #7 on: January 31, 2009, 02:55:54 pm »
Ahh, So it's a door panel off job  :sad:
« Reply #8 on: January 31, 2009, 02:59:15 pm »
Afraid so by the looks of things, and yes...theres a guide for that too lol  :grin:
tbh i think maybe leave the switch standard, your eye doesnt need to be drawn to it and you'll never really see it anyway
although it could bug you
Offline WhiteGTI
  • F-A-S-T
« Reply #9 on: January 31, 2009, 06:16:50 pm »
Nice guide!
Thank for taking the time to do it  :smiley: :smiley:
2006 E46 BMW M3 - 343hp
« Reply #10 on: January 31, 2009, 06:53:06 pm »
great right up shaun, and regards the bojo tools, there great. had a set for ages and they havent changed, bent, degraded in anyway. an absolute must for anybody doin any interior work.
Offline TagnuT
« Reply #11 on: January 31, 2009, 08:06:53 pm »
I like the Light switch - same as the new Scirocco as well. Nice guide too..
« Last Edit: February 01, 2009, 03:49:32 pm by TagnuT »
Bye Bye Edition 30.
« Reply #12 on: February 04, 2009, 09:10:58 pm »
Nice write up.
Where'd you get the removal tools from?
« Reply #13 on: February 04, 2009, 10:56:36 pm »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #14 on: February 04, 2009, 11:13:12 pm »
I have those type, pretty handy.
Stu...
