Author Topic: EVAP EMISSION CONTROL SYSTEM FAULT?????  (Read 28841 times)
Offline jimmy-s3
« on: September 04, 2010, 05:34:11 pm »
Ive had my car checked for the cause of a missfire, suspecting it would be a coilpack!
The fault that has come up is  EVAP Emission Control Sys: Incorrect flow
With possible causes: EVAP Canister Purge Regulator valve (N80) faulty/jammed
                                    EVAP Canister Purge Solenoid valve (N115) faulty/jammed
                                    EVAP Canister Sealing faulty
                                    Pipes between Tank and throttle body leaky/blocked
Can anyone please help me out as im not sure what all this means or where these parts are on the  (AXX) engine?
Any help will be greatly recieved!
Offline snapey
Re: EVAP EMISSION CONTROL SYSTEM FAULT?????
« Reply #1 on: September 04, 2010, 05:46:56 pm »
I'm sure thats something to do with the charcoal canister as I'm sure it's directly associated with filtering certain gases, it's the black box canister in front of the coolant tank with a couple of silicon/rubber pipes popping out of it.
Luke.
If you have to ask why, you'll never understand.
Offline jimmy-s3
« Reply #2 on: September 04, 2010, 05:51:01 pm »
Cheers Luke,
 I'll go and have a look!
Offline jimmy-s3
« Reply #3 on: September 04, 2010, 06:16:43 pm »
Just had a look and everything seems ok!
Ive been doing a bit of searching online and seem to think its the Purge Valve? Does anyone know what this looks like and where it is in relation to the charcoal canister?? Also, what would be up with the charcaol canister to be faulty??
« Last Edit: September 04, 2010, 06:18:38 pm by jimmy-s3 »
  • -Receive: 453
« Reply #4 on: September 04, 2010, 07:14:21 pm »
Do you normally fill your fuel tank to the brim?
Offline jimmy-s3
« Reply #5 on: September 04, 2010, 07:18:11 pm »
No, i only ever fill it 3/4 full.
Also, ive looked at the charcaol canister and one of the connectors on the top twists and pulls off quite easily. Once off, you can see the filter inside the canister but i wouldnt have thought the leak/fault would come from this?
Offline jimmy-s3
« Reply #6 on: September 06, 2010, 08:10:48 pm »
Help me out here please guys!
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #7 on: September 06, 2010, 08:15:41 pm »
I used to have this exact same fault
If you look at this pipe check it's not broken like in the pic (or has a hole in it somewhere) it is really easy to remove to check it.
To remove follow the pipe towards the windscreen to where it meets a pipe just behind the coolant bottle. On the sides of it there are 2 connections you push in and then pull the pipe off. Then the bit you can see in the pic that is still attached to the Charcoal Cannister twists 1/4 turn (can't remember which way but will only go one way and not much force) and then just lifts off. May take a bit of a tug but dont yank. Have a good look over that pipe.
They cost about £8 new from a stealer but i just sealed mine with some Gorilla Glue and it hasn't (touches wood) come back.
I've had a look at 2 other people's cars with this fault and that pipe was the problem in all 3 cases (mine included)
Not saying yours will be but it's a good place to start :happy2:
Incidentally if you have to replace the Cannister they are about £95 from a stealer.
« Last Edit: September 06, 2010, 08:19:40 pm by vRS Carl »
Offline jimmy-s3
« Reply #8 on: September 06, 2010, 08:40:15 pm »
Cheers VRSCarl!
Ill check that pipe again in detail tomorrow!
When i checked the charcoal canister at the weekend, the part on the top that twists off didnt seem to have a secure seal to it. It didnt feel it was a tight fit or anything? Is this usual?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #9 on: September 06, 2010, 08:46:35 pm »
Cheers VRSCarl!
No it should be tight. Not so tight it wont move but i would compare it to an un opened bottle of pop.
Check that the rubber o-ring is seated correctly on it.
By the sounds of it if it doesn't feel secure then that is probably the cause :happy2:
Offline jimmy-s3
« Reply #10 on: September 06, 2010, 08:56:13 pm »
Fingers crossed! :happy2:
Offline martziniuk
« Reply #11 on: September 07, 2010, 08:34:18 pm »
I got this problem too, I replaced the N80 valve but no luck so I took the charcoal tank off and shuck it up a bit, this kept the code away for a while but it has returned.
I have bought a new charcoal cannister to fit sometime but it doesn't really bother me unless the dash light comes on.
This is quite a common problem and quite often dealers replace both the N80 and cannister but try no to brim the tank as this destroys the valve and cannister.
Offline jimmy-s3
« Reply #12 on: September 07, 2010, 09:47:55 pm »
UPDATE>
I sealed the loose hose on the top of the canister and it seems to have fixed the missfire for now!
Just one more question, where is the N80?
nickshirley
« Reply #13 on: March 20, 2011, 03:01:34 pm »
Hello All,
I'm new to this forum so be gentle!
Having read this thread a few times to try and cure the emissions light on my dash, i'm in need of a bit of further guidance.....
Once the pipe (N80?) has been replaced, should the dash light go out immediately if that is the source of the problem?Or is it soemthing that is calculated over a set distance before it goes out?  \\\ive replcaed the hose, but the ligth still burn strongly!
Thanks in advance
Nick
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #14 on: March 20, 2011, 04:14:15 pm »
Mine didn't i had to clear it with VCDS.
