well as some of you may know I had the car remapped at Awesome 10 days ago....
then running home on a cool Sunday evening , WOT 3rd gear 22psi and stutter , stutter , jerk , flashing CEL
backed off and tried again......
At this point Im none too happy and decided to take it easy for a few miles , then tried again , this time the CEL stayed permanently lit
At this point im distinctly unhappy and deciding whether to go to Awesome or the stealers.
I figured given the car drove normally at reduced throttle , and low to mid boost levels , the problem probably wouldnt occur at normal /stock map levels, so the dealer wouldnt be much good
Phoned Awesome monday and they couldnt be more helpful , said to bring it in as soon as I could to read the fault codes.
Car was in today , read fault codes
Misfire cylinder 3 , aha coil packs I hear you say .......
swapped packs to see if fault 'follows' the swapped pack , alas not.
At this point Awesome wanted to keep my car for the day to do some more diagnostic checks.
At this point I was a tad concerned.
I went and picked the car back up , the reason ?
A poor batch of fuel !!!!!
Cylinder 3 is the longest inlet tract , so fuel related issues show up on that cylinder first.
They have added some octane booster and the fault no longer appeared and the car runs sooo much smoother.
Did consider draining the tank , but prob not required.
Anyway I have phoned Tesco and intend to claim at the very least my tank cost back.
It was Tesco 99 on the pump but I suspect it may have been either an old batch or really just 95 ordinary unleaded!!!
I think I may try some Optimax again ! after being a Tesco 99 avid fan
Anyway time will tell , but I had to post as Awesome have proved themselves worthy of my trust in getting my remap there.
Top notch service which i cant fault, and despite my endless questions were always happy to take time out to help.
Something you really need, once remapped , especially as a fault (like this) may not even show in stock mode.
We will see how the next few miles go , but hopefully its just a bad luck experience.
