Author Topic: MK6 steering wheel on to a MK5  (Read 22042 times)
Offline B8CLN
« on: April 08, 2011, 05:45:43 pm »
 :driver:
Hi
I have recently bought a MK6 flat bottom steering wheel without the multifunction to put on to my MK5 golf gt sport without multifunction.  I have fitted it today but my horn doesn't work.  Please can any one help and give me part numbers or advice.
Thanks in advance
Colin
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: MK6 steering wheel on to a MK5
« Reply #1 on: April 08, 2011, 07:42:41 pm »
you need the revision C slipring, what year is your car??
Over the top mod list ;o)
Offline B8CLN
« Reply #2 on: April 08, 2011, 08:04:10 pm »
It's a 58 plate
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 09, 2011, 08:28:25 am »
What Airbag loom are you using?
Does it have a black plug?
Cluster and Key coding
Location Great Yarmouth
Offline B8CLN
« Reply #4 on: April 09, 2011, 10:04:00 am »
It's a yellow plug ,on the mk6 wheel there is also a small black plug which I don't have anywhere to plug it into
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: April 09, 2011, 10:24:22 am »
That is the problem.
You have a loom from a MFSW
You need a loom without the black plug, try using your old one
Offline B8CLN
« Reply #6 on: April 14, 2011, 08:33:36 pm »
At last got my horn working had to fit a new wiring loom to the airbag and that was it.thanks to everyone that helped especially Gareth at www.vwcruise.com check this guy out for retro fitting vw stuff he,s spot on  :happy2:
cheers Colin.
Offline apollo13
  • -Receive: 47
« Reply #7 on: April 14, 2011, 08:36:08 pm »
cheers Colin.
Glad you got it sorted Colin  :happy2:
Although there are people on here that will do retrofitting cheaper than those guys  :grin:
Offline B8CLN
« Reply #8 on: April 14, 2011, 09:19:35 pm »
No problem cheers
Offline hkp
« Reply #9 on: August 27, 2011, 10:31:17 pm »
Hey Colin, just resurrecting this thread!
So to fit a Mk6 Non MF wheel to a Mk5 Non MF manual car, then no mods are needed as long as you have the correct airbag loom?
I was under the impression that if you wanted to fit any Mk6 wheel (even Non MF) you needed a C revision Slip ring and an updated CH steering wheel control module..
I'm not too fussed by multi function as I have an aftermarket stereo anyway. If this was plug and play then I'd definitely do this mod!
  • -Given: 243
  • -Receive: 154
« Reply #10 on: August 27, 2011, 10:48:52 pm »
If you want MF you need those 2 parts, and if you have CC you need the mk 6 CC stalk also  :happy2:
Offline hkp
« Reply #11 on: August 27, 2011, 10:52:44 pm »
Hey Danish,  Thanks for the reply :)
I don't want MF, and haven't got it currently.. Will I still need the control module? I was assuming from Colin's post above that I wouldn't...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: August 29, 2011, 10:03:32 pm »
No, it's a straight swop
Offline hkp
« Reply #13 on: September 16, 2011, 06:52:52 pm »
Damn. I've got the little black plug too in my non MFSW wheel. I guess this supplier in Portugal (where they all seem to come from) only has MFSW Airbags. Does anyone know the correct loom I need to fit onto a non MFSW mk5?
Thanks!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #14 on: September 16, 2011, 07:00:41 pm »
I have one sitting in my garage. Want to do a swap?
