Author Topic: Fan replacement.  (Read 6413 times)
Offline Bane
  • "I was born a handsome man and now I'm half a goat
Fan replacement.
« on: May 07, 2011, 12:57:21 pm »
Had to replace the auxilary/aircon(the smaller of the two) fan on the Golf yesterday...not a job that I would look forward to again!
I thought that it would be straightforward,but when I opened the bonnet and saw just how little space there was between the fans and the engine-not to mention all the pipework that was in the way-I realised that this was not going to be an easy task.
I started off by locating all the screws holding the front bumper in place and removed them all,including the two hidden behind the grill and the bloody awkward ones in the wheel well....if I ever meet the 'genius' who came up with that design,I'd string him up from a phone pole...
Then I found the eight bolts (four on either side) holding the entire front assembly to the chassis and undid them,along with the three torx type screws on either end of the slam panel and using a hydraulic jack placed underneath,gently eased the front assembly forward.
This allowed me enough room to get at the four screws holding the fan assembly to the radiator...the bottom right one being the most difficlut to get the ratchet to...and got the assembly off.
Undid the three nuts holding the motor/fan to the mount,swapped over to the new one and reassembled the whole caboodle.
Time taken-4 1/2 hrs-- 4hrs 25mins to work out how to take it all apart and put it all back together and 5 mins to change the fan.....bloody modern cars. I think I might go back to a MK2 GTI......... :laugh:
Offline alexperkins
  • -Receive: 99
Re: Fan replacement.
« Reply #1 on: May 10, 2011, 12:33:31 pm »
so easy to change on a mk2 GTI indeed!
Offline AnSGTI
  • 2012 GTI Edition 35
« Reply #2 on: May 10, 2011, 01:36:49 pm »
This would probably have been of benefit to you then:
http://forums.vwvortex.com/showthread.php?4902624-DIY-Cooling-Fan-Replacement
Mine needs doing, my large fan sounds like a jet powered rocket when it comes on as the smaller of the two has seized. I've read various threads and some people have been able to break the case once the fan is removed and re grease the bearing's and the fan will work again.
May I ask where you got your replacement fan from? VW have quoted me £155.64 for a Siemens one, I've had a price from EuroCarParts for O/S cooling fan (ECP Part no: 213440950) £107.04 - no idea if this is Siemens or some random patent part
Offline alackofspeed
  • -Receive: 24
« Reply #3 on: May 10, 2011, 07:33:32 pm »
I jacked up the front of my car up, and dropped the fan out the underside. All I removed was the intercooler to throttle body boost hoses. Took about 30 minutes.
Just thought I'd add that, should someone else decide to remove their fan, and want an easy solution.
