Author Topic: Edition 30 : APR Stage 1 review  (Read 49246 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« on: April 02, 2009, 11:40:15 pm »
I have now completed 8k miles on this remap and feel I have enough info to comment
Why
Because you can  :evilgrin:, if you need to ask why, I cant tell you anything that will make you understand.
Seriously though the ED30 with its K04 turbo was heavily 'detuned' from the factory.
There is significant available power 'headroom' should you want it.
The engine can take it reliably so dont worry.
As a standard car the ED30 is a balanced package, brakes/suspension/grip/power etc
For many of us though, you've just got to scratch that itch.
For me I had just come from a 343bhp E46 M3, so I really felt I could do with a bit more power
Which remap ?
Heres a list of criteria you may wish to consider when deciding on a remap :
Customer base (size)
customer feedback
type of customer profile
distance from you
cost
development time and resource to produce product
updates
are they VW specific or other makes too?
time in business for this specific car make
dyno plots (both from company and from forums , they differ greatly). shape is as, if not more important than ultimate numbers
AirFuelRatio data, EGR temp data etc
ability and type of switching , stock vs mapped mode
adjustable (only REVO can do this)
For me APR and Awesome combo gave me the match.
Remember its not just the map but the person/company putting the map on that matters especially if you have an issue.
Sourcing
Supplied and fitted by UK APR dealer :  Awesome GTI Irlam Manchester :  http://www.awesome-gti.co.uk/
Remap = £499 (std like map + 98 Octane remap), includes throttle body align and fault code reset and security lockout
Cruise Control = £199 (available cheaper from a VW dealer OR fitted by vrstu on this forum but given my location I trusted Awesome to do it all)
APR Europe
APR Main
APR map is flashed which contains 2 side by side maps (one OE like , one APR), these can be selected through the cruise control stalk.
Fitting
Awesome ECU flash by cable
Before and After Dyno if requested
Included Cruise Control fitting
I had chosen to run my car in, and had completed 10k miles before remapping
Other versions
There is so much choice so I will leave it up to you, but others to consider are
REVO
GIAC
Superchips
Richter
Plus Points
Over 300 bhp  :evilgrin:
Over 300 lb/fts throughout a wide band
Fuel economy virtually OE 30 mpg average commuting
Huge spool torque peak = fab overtaking urge 6th gear
after initial peak subsides , it still pulls hard to the limiter too if thats your thing
Works well with ESP (WALK fitted at same time too)
Controllable on the throttle like OE map within reason
Very smooth , no known 'glitches' / 'hiccups' for accel/decel and usual driving styles
Pulls from idle just like OE map
Switchable to OE equivalant map using Cruise Control (its not an OE map though), drives just as OE
OE map used for dealer visits and problem diagnosis
Flash count not incremented on successive changes (my understanding is that its incremented once the first time but not after)
Maps can be locked out with a security code for dealer visits (but in depth analysis WILL show a remap)
Other options available , fault code erase , throttle body alignment etc (I got them free as part of a deal at the time)
Future tuning upgrade path Stage 2 . Stage 2+ (APR HPFP) available
APR Well respected company, large customer base
Awesome have also proved there worth 5 times over when I had issues , this was worth ££££ to me.
Forum trawling indicates APR have chosen specific way to map ED30 for EGR , AFR values etc.
Protection maps still enabled for AFR/EGR
Its bloody quick    :laugh:
Minus Points
wheelspin is available on demand at relatively high speeds 70mph, car in the wet can be tricky and requires caution.
wear on other components in the drivetrain will be accelerated.
For manual owners budget for a clutch (VWR paddle) is a must (mine has survived so far.....)
DSG owners may want to have more regular oil service + consider gearbox remap (increases clutch plate clamping load)
LSD would be a distinct advantage and would allow full use of the 300+ horses
Good tyres are mandatory and they wont last very long either (8k miles for Michelin Pilot Sport PS2 = bald!)
Huge spool torque peak shocks tyres loose, can hamper progress and can be counterproductive (but can be worked around mostly by throttle progression) APR choose to do this type of spool for some reason.
brakes are now not up to the job for medium / continuous use.
Increased insurance premiums (done on a power basis you are looking at +30% premium)
Not adjustable in any way (yet! there is talk of this changing soon)
Map is 98 + RON only
You will be doing + 30 mph more than you expected, be careful
you wont be able to stop just at a remap...
Summary
What a difference , night and day doesnt quite cut it, its dramatic  :driver:
The sheer urge is seriously addictive, you can be a loon or just surf the wave of torque...
Although its hard on the clutch I love the pull in 6th gear at 70 ish mph , instant urge.
The big thing is that the increase is so dramatic it disturbs the 'balance' of the car.
Ideally you will also need LSD , clutch (manual), suspension , brakes to restore that balance, where each component is a match for the others and not overwhelmed.
I'm happy without these for now, but I know the car could be so much more with them.
If you can only afford the remap then you are still going to be more than happy, I know I am
Highly recommended remap.
Highly recommend Awesome for customer service and the way they work  (see additional info below , and just shop around and haggle on prices  :wink:)
Yes , given the choice again I would buy APR again
For me the future holds restoring the 'balance' plus maybe adding a HPFP to flatten the torque curve out.
(the curve currently does  boost , drop then hold, with a HPFP it should just boost and hold ......)
Do the research, make your own choices, but most of all get a remap (std GTI or ED30) its definitely worth it
Facts and Figures
(all data is taken from an in dash DEFI gauge)
standard ED30 : Awesome dyno : 98+RON fuel
11-12 psi peak , 10 psi hold
255 @ flywheel
230 @ wheels
230 lbs/ft , 200 lbs/ft plateau
Ed30 APR stage 1 : 98+RON fuel
22 psi peak , 17 psi hold
310bhp @ flywheel
280bhp @ wheels (roughly?)
376 lb/ft peak , 300 lbs/ft plateau
Boost levels can vary on fuel type
(Tesco 99 RON gives best 'hit', other high octanes give best economy with a reduced hit)
Rough estimated gains from the graphs are
+50 bhp
+70 lbs/ft (
peak value is increased by  + 146lbs/ft!)
Note Im careful to state relative differences rather than exact values as im aware of the 'dyno lottery'
Dyno runs were taken on different days in different conditions so its not gospel but a guide  :happy2:
Additional info
whoosh.....stutter.....CEL my remap story and how it was resolved by Awesome
http://www.mk5golfgti.co.uk/forum/index.php?topic=263.0
12thSept09 : added quote from Keith@APR  for some great info. This was after some questions about remapping in a recent thread
http://www.mk5golfgti.co.uk/forum/index.php?topic=7508.0
I am not really sure how it works with Revo or Bluefin but I do know how it works with APR
We are the only company in the world that adds additional coding architecture to the ECU.  This new coding allows the ecu to flash itself much like the dealerships, Bluefin and others flash the ecu's through the obd 2 port except it all happens internally.
ECU files are typically 2mb of total size including some marked and addressed but unused space.  It is in these unused spaces that we insert our flashing coding and our operating maps or modes.
When you use your cruise control to select the mode you want, the ecu completely reflashes itself with a completely independent set of maps for that operating mode.
For example, going from 98 ron performance to stock requires the ecu to reflash itself with all of the operating maps that are different from your exact oem code.  The 98 ron performance maps that are different than your oem code is then compressed like a .zip file and stored in the inactive memory locations until you use the cruise control to tell the ecu to reflash itself back with the performance maps.  This means that other than the coding it takes to flash the ecu and the performance maps that are compressed and stored in an unused memory location, your ecu is 100% OEM operating maps and code.  Not maps that we've inserted that have been detuned but completely stock mapping.  In fact, the first part of installing an APR ecu upgrade with DPP is to extract your OEM performance mapping to be compressed and stored in the unused memory location.  This means that not only are you getting an exact OEM stock mode, you are getting YOUR EXACT OEM STOCK MODE.
The performance mapping and flashing code that is stored in the unused memory locations is less than 2% of the total file and the total file size remains the same OEM 2mb.
It is technologically impossible at the dealership level to detect APR ecu modification as long as you are in stock mode and security lockout is turned on.  The only way that the 2% of different coding can be detected is by Bosch Engineers or VAG calibration engineers that can completely extract the code on your ecu and compare it line by line to a version of the OEM code to find that 2% in difference.  It takes alot of man hours and expertise to be able to do this and chances are you will never see this technology available at the dealership level.
Furthermore, some percentage of the Bluefin flash must not be OEM as well or you would be able to use you bluefin flasher on any ecu.  The bluefin device must write a piece of code like a key or identifier in your ecu the first time it flashes it to know that the device belongs to that particular ecu.  So, bluefin is less than 100% exact OEM code as well.  Unless they write the code in the bluefin device which would make it very easy to unlock and use on every ecu you run across.
From what I understand by reading Revo's patent info, they do detune the performance map back to stock like behavior.
14th Sept 09 : more data added as I feel its very useful info  :happy2: , thanks Keith
Quote from: Keith@APR
Quote from: john_o on September 12, 2009, 04:57:23 PM
Have to say thats added a bit more data to my memory banks thanks Keith
I thought it was switched not reflashed each time!
which brings on my questions.........
1.When I select std map it takes 10 seconds at most to select the map via the cruise.
So why does it take longer when 'flashing' at Awesome etc? (or is it always 'seconds' to flash the ECU code?)
2. Surely switching between maps would have been 'safer' ?
I guess youve chosen this method so it is OE in stock mode but is this reliable and safe?
The ecu memory will also have a flash limit for the number of times you can do this, any idea what it is?
(I  assuming Id have to switch to and from stock each day for 10yrs + to even get to this limit???)
1.  The first step of DPP is to completely read out your entire ecu and our server compares your oem binary to other oem binaries' and verifies the integrity of your ecu.  This takes about 2-3 minutes depending on ecu.
Once the binary is read and verified, our DPP server compiles our performance data with the remaining maps of your oem code that we don't change like start up maps, some part throttle mapping, etc.
When the compilation is complete, another 2-3 minutes, your entire ecu is reflashed.
Add in another 3-5 minutes for internet data transfer and any que in the DPP servers from others flashing and there is your 10-15 minutes of actual DPP flash time.  The installer spends another 10-15 minutes entering in your customer data, setting up the flash and using a diagnostic tool to verify the flash, etc.
When our engineers use an internal flashing tool that is much like the EMCS works internal to the ecu, we only flash the calibration sectors of the ecu which is only a portion of the 2mb, don't have to compile the total OEM binary, don't have to wait for any internet or DPP ques, it takes about 10-15 seconds.
2.  There are several flashing counters and other protocols in the ecu that can limit the number of flashes or alert the oem dealership to more flashes than the ecu should have.  Part of reading your oem binary is to determine the number of flashes your ecu has seen prior to coming to us.  This allows us to rewrite your flash counters back to their same number of flashes before you came to see us so noone will know your ecu has been flashed off of the OEM dealership network.  EMCS doesn't have to worry about the counters as it flashes the internal memory of the ecu in a way that the counters aren't designed to record as a flash.
Internal ECU flashing is a more elegant and powerful solution and keeps the OEM code exactly OEM.  Its a more advanced way of doing it and also provides some code integrity and security protocols.  Almost every tuners' code can be stolen and from what I understand our product is more secure than most and we go to great lengths to insure it stays that way and internal ecu flashing helps with that as well.
[EDIT : Nov 09 : 31,000 miles]
Heard that there were some updated files ready from APR, so
I have just had the v2.2 stage 1 APR file flashed onto the car by Awesome.
Its free (as part of your original payment). No idea what the changes are but so far feels stronger and smoother
[EDIT Nov 2010 : 42,000 miles : now switched to REVO as AwesomeGTI no longer support APR, check out Edition 30 REVO Stage 1 review ]
[EDIT Feb 2012 : 59,000 miles : still running REVO stg1 but APR appear to have updated their maps to make them 'better'
http://www.mk5golfgti.co.uk/forum/index.php/topic,41682.0.html.
Theres also a 'linear' throttle map available for REVO which I havent tried yet]
« Last Edit: February 04, 2012, 07:55:52 am by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Edition 30 : APR Stage 1 review
« Reply #1 on: April 03, 2009, 12:21:09 am »
Another great review John_O, thanks for taking the time to do this  :happy2:
« Reply #2 on: April 03, 2009, 02:46:41 pm »
You didn't mention in the negative's about the pod sprint times going backward with your map.  :evilgrin:
Very thorougher and informative as usual bud.  :drinking:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: April 03, 2009, 03:05:37 pm »
my map ? have I missed something TC?
My poor sprint times are down to the driver and preserving the clutch (i.e. limiting the amount of slip time), given more practice I'm sure theres a lot to come off them ....... I feel Ive been more than honest with my review ..
Red ED35 5dr DSG
BLOG | BUILD
« Reply #4 on: April 03, 2009, 03:08:18 pm »
Thats why i underlined the word your, trying to avoid people mistakenly thinking i meant the APR map.  :rolleye:
« Reply #5 on: April 04, 2009, 06:04:59 pm »
Excellent review as usual - I particularly think that the criteria you list for deciding which remap will be very helpful to people. :happy2:
Are you the guy who accidentally popped their car into reverse at the start line at Santa Pod? (Hence TC's comment)
Offline illyun
« Reply #6 on: April 04, 2009, 06:16:47 pm »
That figure for the standard Ed30 seems very high at 255 bhp... Mine only made 227bhp on JKMs dyno along with most of the other standard Ed30s on there.
Offline MK1Campaign
« Reply #7 on: April 04, 2009, 06:35:52 pm »
I saw a standard one make 265bhp at Stealth Racing and their rollers are known for being pretty accurate.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #8 on: April 04, 2009, 10:27:39 pm »
cant believe you would think that was me RR , Im hurt  :wink: :grin:. No it wasnt, TC is referring to my poor times at the runs in Jan (15 sec in a 300bhp car is pants..) , he enjoys nothing more than taking the mickey.......
@illyun
Thats why I stated relative hp increase as opposed to actual numbers as gospel. From the data on this forum and others I expect 250 bhp flywheel at most rollers for std ED30 (+/- 10 hp dependent on fuel type used +conditions)
and 230 for JKM rollers. Therefore if I ran my car at JKM I would expect to see 290bhp  :happy2: as the remapped figure.
Interestingly I asked APR about my dyno plot and it seems the super high torque figure peak can be induced by the way the load is applied to the rollers......
Red ED35 5dr DSG
BLOG | BUILD
Offline KRL
  • -Receive: 29
« Reply #9 on: April 08, 2009, 12:25:32 pm »
Fantastic review.  Good work  :happy2:
Offline KRL
  • -Receive: 29
« Reply #10 on: April 08, 2009, 12:33:07 pm »
INot adjustable in any way (yet! there is talk of this changing soon)
Would be very interested in hearing more about this.  Where have you seen this talk?  Are APR planning on using V-Tune like they did for the 1.8T?
http://www.goapreu.com/products/vtune.html
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #11 on: April 08, 2009, 01:09:30 pm »
@ All : thanks for the positive comments , any more info you need just ask....
@ KRL : You know as much as I do  :grin:
Arin on golfmkv.com kindly contacted me about my spool questions to give me the full run down and indicated that there are some new maps due out for non US cars  :happy2: (edition30 being one of them) very soon.
Whether that includes new functionality I dont know........ :party:
All I know is I need new front tyres  :signLOL:
Red ED35 5dr DSG
BLOG | BUILD
Offline KRL
  • -Receive: 29
« Reply #12 on: April 08, 2009, 01:52:18 pm »
Yes I did see your post on golfmkv.com.  What was the conclusion about the spooling then?  From your reply I am guessing the spooling might be smoothed out in the new SW...
Ref V-Tunes - If APR were to release it for the 2.0TFSI it would be great and would probably sway me into choosing APR over REVO.  Like you I appreciate APR's tuning philosophy and ethos  but am also a bit of a tinkerer so would love to have the ability to mess around with different settings etc.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #13 on: April 08, 2009, 04:40:53 pm »
the curve is a mix of APR delivery + the way the dyno was set up at the time.
Gonna get car on dyno again and it will prob look less peaky.... :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline Msportman
« Reply #14 on: May 05, 2009, 10:00:32 am »
Any news on the above John?
I've just joined this forum having just selling my APR Stage 3+ MKIV...Jim's first Golf conversion done some 2 ago.
I've been an APR fan for some time tracking the MKIV after he did the first APR stage 2 mapping when it was first launched.
The MKIV had everything done intially before Stage 3....ie Quaiffe, FMIC, Milltek DP CAT exhaust, Koni ride height susoension. Neuspeed ARB's, poly Bushed and Tarox 6 pot 2 piece brakes running Inters...car put out 230bhp on stage 3 on AUM engine....Stage 3 after rebuilding engine was putting out over 350bhp and 350lbs of torque....quick road car.
Back to your car I am considering cruise and APR map but wanted your oppinion....I see Blufin delivers slightly differently....slightly less peaky at front of map or is the rollers?
Did you consider Bluefin/Revo/Chipped UK/APS or GIAC?
Looking at tracking her so I know what's to be done but on the road it seems very good all round....brakes are a bit over servoed but strong....big brakes are nice but horrendously expense to change discs...Tarox want £550 plus VAT just for discs and £200 for pads on their 6 pot kit!!
Ian
Pearl Black Edition 30 3 Door. DSG. (3rd Edition 30)
Maybe on the too do list: APR Stage 2+, KW Clubsports, Brakes, Diff.
