Author Topic: Retrofit OEM xenon headlights, what's involved?  (Read 40261 times)
Offline Timvgti
« on: November 08, 2011, 01:57:36 pm »
Hi Guys,
I'm looking for a good original pair of xenon headlights with original 4300k d2s lamps, original ballasts/ignitors and a pair of kufatec 12 to 10 pin adapter cables.
Offered plenty at local marketplaces/ebay/etc (The Netherlands), so looking for the best price/quality/completeness before buying one.
I have a VW Golf V GTI from 2005 with original halogen headlights.
I don't need the auto-height-adjustment system and the headlight-washer-system (only requiered on >2007 cars over here).
So what's involved?
- Is there a good 'how-to'?
- How to (partly?) remove the bumper and halogen headlights?
- How to install the new xenon headlights correctly (beam patern/height)?
- Is it still possible to adjust the height using the small scrolling wheel near the light-switch (positions: -&1&2&3)?
- I do not necessarily need the xenon high beam function. H7 as high beams is good enough for me (if I do want to use the xenon shutters/high beam, I need to connect the extra wire coming from the kufatec 12-10pin adapters to the cecm. How to do this?)
- Are all 12 to 10 pin adapters equipped with the extra high-beam-xenon-shutter-wire?
- What/where do I need to recode in vcds? (Xenon with shutters, xenon without shutters? What boxes to check?
Thanks,
Tim
« Last Edit: November 08, 2011, 02:00:50 pm by Timvgti »
Offline Timvgti
Re: Retrofit OEM xenon headlights, what's involved?
« Reply #1 on: November 09, 2011, 10:26:55 am »
Found a 'how-to': http://www.myturbodiesel.com/1000q/a5/HID-retrofit-Jetta-a5.htm
But doesn't answer all my questions, like if it's still possible to use the height-adjusment-scroll-wheel?
Also the how to is not complete if you are not a member on myturbodiesel, like me...
« Last Edit: November 09, 2011, 10:30:07 am by Timvgti »
Offline Timvgti
« Reply #2 on: November 14, 2011, 12:22:27 pm »
Guys?
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #3 on: November 14, 2011, 12:42:29 pm »
video guide here from ECS tuning
then the Kufatec looms plug straight in. additional wire NOT required.
Level wheel will not work.
xenons without shutters in VCDS required if the additional wire is not used.
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline Timvgti
« Reply #4 on: November 15, 2011, 03:51:13 pm »
Thanks 'Parks'!
So no manual height control anymore?
How to properly install the headlights at the correct beam-heights?
Mark the old headlight beam patterns on the garage door?
« Reply #5 on: November 15, 2011, 05:22:08 pm »
Thanks 'Parks'!
CORRECT
Easiest way is to take it down to an MOT tester and get them to set them... i did mine myself though
That should work, but don't move the car once you've marked them up
Rich
Offline marko
« Reply #6 on: November 04, 2012, 10:06:06 pm »
anyone any idea what repair wires are needed to connect to cecm to operate hi beam shutters ???
have the kufatec looms with the extra wire but i need little pin connections for the cecm
 :confused:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Retrofit OEM xenon headlights, what's involved?
« Reply #7 on: November 04, 2012, 10:16:10 pm »
The kufatec loom should already have the extra wire on each connector, with the pin attached ready to slot into the cecm.
Does yours not have them attached?
VCDS (Preston, Lancashire)
Offline marko
« Reply #8 on: November 04, 2012, 10:22:24 pm »
no man...got them supplied with the headlamps but last owner ran the h7 hi beam so he cut off the extra wire bar last 6 inches
 :confused:
Offline marko
« Reply #9 on: November 05, 2012, 01:37:48 pm »
anyone have a clue??
getting nowhere with local dealer...
 :indifferent:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #10 on: November 05, 2012, 04:09:26 pm »
Take a picture of the actual connectors. Could be the same as the seat ones iv just bought!
Offline marko
« Reply #11 on: November 05, 2012, 05:04:12 pm »
didnt want to strip out the cecm until i have all the bits i need to finish in one go
found some info on a US vw site.....
thanks man
Offline marko
« Reply #12 on: November 05, 2012, 05:09:14 pm »
seems 000 979 025e and 000 979 151e are the two connecting terminals needed for anyone who wants to wire in the hibeam shutter on their xenons
 :happy2: :happy2:
Offline Richie18-1987
« Reply #13 on: November 23, 2012, 01:18:57 pm »
Hi
Sorry to sound dumb but what are you referring to when you say xenon shutters?
I've never heard that term before also you say xenons with and xenons without
Whats the difference I thought that were all the same.
I haven't done this mod yet so would be handy to know when I come round to it.
Regards
Rich.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #14 on: November 23, 2012, 04:42:13 pm »
The shutters when wired up will open on high beam, using the xenon for high beam illumination in addition to the halogen bulb.
Without them wired up, only the halogen bulb is used.
All standard golf xenons have the bi xenon shutter, but you have to run a wire to the cecm to activate it.
Jas
