Author Topic: Does your car sit slightly lower on one side?  (Read 8081 times)
Offline kiddfrost
« on: November 17, 2011, 10:51:23 pm »
I recently fitted some Eibach Sportlines and a couple of weeks later noticed that the driver’s side of the car sits about 5mm lower than the passenger side. I think it was like that before but just didn’t notice it because of the larger wheel to arch gap.
Before I start trying to fix it does anyone know if this is normal?
Maybe due to road camber, the car being originally designed for LHD so the driver would cancel out the difference or tolerances?
Re: Does your car sit slightly lower on one side?
« Reply #1 on: November 17, 2011, 11:27:32 pm »
New springs??
Offline AjayB
  • Golf GT TDI
« Reply #2 on: November 17, 2011, 11:45:14 pm »
I noticed the exact same thing from my passenger rear today. I'm sitting on 35mm h&r springs.
Build: http://www.mk5golfgti.co.uk/forum/index.php/topic,40699.0.html
Golf MK5 GT TDI | 35mm H&R Springs | Silver Cabon Fibre Inlays | 20% Rear Tints | Backbox Delete- Dual Tips | GTI Rear Valance
To Do: RNS/RCD510 | FBSW | Black BBS CH 18"
Offline dub singh
  • Snakebite Chasers...
« Reply #3 on: November 18, 2011, 02:21:20 am »
Petrol tank is on the drivers side too.. weight of the tank and petrol..?
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline PDT
  • -Receive: 142
« Reply #4 on: November 18, 2011, 01:51:52 pm »
Try and park it on perfectly flat ground, measure from centre of each wheel to lip of arch (90degrees from ground, i.e straight upwards)
Normal roads are often very uneven and can cause height to look a bit wrong.
Offline AjayB
  • Golf GT TDI
« Reply #5 on: November 18, 2011, 01:55:59 pm »
I heard today that the left side of a car is always slightly lower due to the drivers side purposely being a tad higher to compensate for when the driver is sat in?
Offline Ducky76
« Reply #6 on: November 18, 2011, 02:21:38 pm »
Was the missus sat in the car while u were measuring  :smiley:
Offline Eccie
  • -Receive: 25
« Reply #7 on: November 18, 2011, 02:37:23 pm »
 :signLOL:
Offline AjayB
  • Golf GT TDI
« Reply #8 on: November 18, 2011, 02:42:40 pm »
Haha no1 in there for me  :P only thing in there was a Greggs chicken bake pasty mmmmmm  :party:
Offline kiddfrost
« Reply #9 on: November 18, 2011, 04:37:29 pm »
New springs??
Brand spanking new
At least its not just me
Less than a quarter of a tank when I measured it
Pretty sure she wasn't but I'll ask her to make sure she didn't slip in while I was so engrossed with the tape measure  :P  :smiley:
It was parked in my garage which is quite level. I'm pretty sure it is dropped as when you try and put your hand in the top of the wheel arch there is a smaller gap on the RHS. I did measure it as you said but from the lip of the centre cap.
I'd appreciate it if a couple of guys could see if their cars are out by measuring it like PDT has suggested?
Offline Little_Dave
« Reply #10 on: November 18, 2011, 04:46:39 pm »
Sure there was a discussion about this on another forum and they said it was normal for a lowered car to sit slightly lower on one side but i can't remember what the reason given was..... Guy was asking about his Jetta and i think they said it was to do with the related extra natural camber you gain going lower or possibly the extra strain on the rear axle..... sure someone will correct me if i've got it muddled up  :laugh:
Dave
Offline S800BRN
  • -Receive: 27
« Reply #11 on: November 18, 2011, 08:22:33 pm »
My Cupra K1 sits ever so slightly higher on the passenger side too, more so at the rear. Lowered on H&Rs, btw.
Offline gazbutS3
« Reply #12 on: November 18, 2011, 09:39:20 pm »
I've noticed this on both my GTI's and the S3 also the rear left wheel looks like it sits further in the arch on all 3, only a few mm but my OCD side has spotted it  :smiley:
Offline AjayB
  • Golf GT TDI
« Reply #13 on: November 18, 2011, 09:51:10 pm »
Things get more noticeable once the car is dropped and the gap between arch and tyre is reduced! on normal springs nothing appears out of place...
Offline patrickcullen87
« Reply #14 on: November 19, 2011, 11:01:41 am »
yeh ive noticed this to, mines sits lower on the passenger side than it does on the drivers side
Admin Notice Sig Removed - Signature images should be no bigger than 450 pixels wide x 150 pixels high
