Author Topic: Key fob won't unlock doors?  (Read 76365 times)
Offline heavyd
  • -Receive: 29
« on: March 04, 2012, 07:33:43 pm »
A mates of mine has this problem with one of his keys in his mkv gti.
He's tried changed the battery in the fob, the key starts the car ok, but the lock and unlock buttons don't work.
Will he need the dealers to do a £75 reprogram, or is there any other way of sorting it out?
Thanks in advance for any suggestions :happy2:
Offline mvb12
  • -Receive: 64
Re: Key fob won't unlock doors?
« Reply #1 on: March 04, 2012, 07:36:29 pm »
+1 mine started playing up last week. can lock and boot pop, but can't unlock :surprised:
haven't tried a new battery as yet but will get round to it soon.
Offline skard
  • -Receive: 245
« Reply #2 on: March 04, 2012, 07:49:17 pm »
heavyd - if you have VCDS you could try re-syncing it to the CCM (by clearing all remotes then re-adding them). There was a manual procedure on here lately to do this, but can't recall who posted it right now (may have been apples12?).
Could be something like buttons were pressed too many times out of range.
I had the same issue a few months back and ended up buying a used remote in replacement as I couldn't get my fob to sync.
mvb12 - seems like your problem is different, and you maybe have a physical problem with your buttons unless your fob LED lights up when you press unlock?
Changing the battery is always a good start for these problems.
Offline apples12
« Reply #3 on: March 04, 2012, 07:49:30 pm »
wont need dealer to do a reprogram...
tell him to sit in the car, lock the door using the button on the door
insert the key into the ignition and turn the IGNITION on only... press the unlock button about 8-10 times, then press the unlock button 8-10 times too.
remove the key and try locking/unlocking it should work...
worked on my mates mk5...no need to go to dealer! its something to do with only having 40seconds to change the battery!
MK6 GT TDI  - CW - LUX pack
GONE
Offline mvb12
  • -Receive: 64
« Reply #4 on: March 04, 2012, 08:00:32 pm »
Just had a play with my keys and no lights come on when i press either of the buttoms... so hopefuly it is the battery which is on the way out.
Offline heavyd
  • -Receive: 29
« Reply #5 on: March 04, 2012, 09:17:53 pm »
Thanks for info. Lad reckons it still doesn't work. So must need  dealer recoding or a new fob. If the immobiliser works, it must be the fob at fault?
Offline apples12
« Reply #6 on: March 04, 2012, 10:55:46 pm »
if after changing the battery the little red light still doesnt flash, then its the lower remote part which is faulty...
if you purchase a used remote off ebay, you can replace the lower part (the bit with the buttons on it) and attach the top part (the key bit with the all important immobilizer chip and key) from your original key
once you've got a used 'working' remote with which the red light lights up when you press the buttons then you can code it to your car using the method i detailed above or using vcds... the dealer will want to charge you an arm and a leg and spin you the line that you can only replace the entire key and not only the lower portion!
MVB12 - when you change the battery try to be as quick as you can about it! i suggest you have small 'jewellers'/watch flat screwdriver handy to pop the old battery out, i was told by the vw service guy that the remotes have 40seconds within which the battery must be changed otherwise they need recoding...
good luck chaps  :happy2:
GONE
Offline mvb12
  • -Receive: 64
« Reply #7 on: March 05, 2012, 12:38:35 pm »
cheers apples,
Will advice once i get round to it.
Offline mvb12
  • -Receive: 64
« Reply #8 on: March 24, 2012, 02:22:19 pm »
battery changed, problem solved!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: March 24, 2012, 02:29:04 pm »
The correct procedure to relearn a remote is as follows -
Quote
Using a spare key switch the ignition on.
Insert the key to be programmed into the driver's door lock.
Manually lock the driver's door using the key.
Press the Lock or Unlock button on the fob once.
Wait for a least one second.
Press the Lock or Unlock button on the fob twice.
The vehicle horn will sound to indicate correct programming.
Can be found on my website - http://octavia-vrs.com/cms/content/key-immo-coding
Stu...
Offline TonyZed
« Reply #10 on: March 28, 2012, 08:14:53 pm »
Quote
And if that doesn't work????????? :confused:
I'm sure(ish) that it has worked, and I've put in a new battery.
Car is a 2005 Gti.
TonyZ
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: March 28, 2012, 09:38:09 pm »
Has it worked?
Stu...
Offline TonyZed
« Reply #12 on: March 29, 2012, 11:47:52 pm »
Has it worked?
No!  :sad1:
I keep trying all the variations without luck, so I'm at a loss. I'll have another go at the weekend.
TonyZ
Offline skard
  • -Receive: 245
« Reply #13 on: March 30, 2012, 06:28:30 am »
No!  :sad1:
TonyZ
I replaced a fob a few months back, one of mine suddenly stopped working even although the LED lights up and a new battery was put in - still nothing.
Have tried the procedures and also to re-adapt it to the CCM in VCDS - I think some fobs just die.
Offline dalco
« Reply #14 on: December 24, 2012, 11:53:52 am »
My fob lost its code, the LED was staying on when i pressed lock and flickered when i hit unlock / boot.
Did the procedure above, Key in ign lock/unlock 10 times and boom works...!!!!!
Well done & Thankyou
