Author Topic: G201 Sensor - ABS Pump/Control sensor module  (Read 20907 times)
Offline dub singh
  • Snakebite Chasers...
« on: March 07, 2012, 12:15:17 am »
Both ESP and ABS light came on the dash permanently, checked it with diagnostics and it turned out to be the dreaded G201 sensor  :sick:
Since its quite a common fault, VW knew about it but didnt admit it.. typical!
They do however offer a repair service kit at a price of £600!!
Has anyone else encountered this problem? Anyone else use the repair kit or any other method of repair?
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline Dario
  • booosting... :)
Re: G201 Sensor - ABS Pump/Control sensor module
« Reply #1 on: March 07, 2012, 12:53:28 am »
I Have this problem
Quote
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0109
   Revision: 00H35001
   Coding: 143B600D092400FC280C06E4902200413400
   Shop #: WSC 18924 000 1048576
   VCID: 74ECDE8E28E139BC
2 Faults Found
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 80023 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 2
                    Count: 2
                    Count: 13056
                    Count: 8193
                    Count: 43776
                    Count: 0
                    Count: 0
                    Count: 0
01130 - ABS Operation
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 79885 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 4160
                    Count: 32768
                    Count: 4608
                    Count: 125
                    Count: 48438
                    Count: 3628
                    Count: 768
                    Count: 0
so if somebody can help me also? :)
thnx
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: March 07, 2012, 09:05:34 am »
I found this on Ross Tech regarding the repair kit -
Quote
When found in MK60 ABS/ESP Brake Systems:
Check if the Repair Kit documented in TPI 2024465 or 2025290 with the Part Number 1K0-698-517-B is compatible, using the Repair Kit allows to replace the Hydraulic Unit (N55) and the Brake Pressure Sensor 1 (G201) separate from the Control Module which will reduce the Repair Costs.
Which lead me to this - http://www.briskoda.net/forums/topic/190784-how-to-repair-espabs-fault-with-vag-repair-kit/
and this - http://www.pistonheads.com/gassing/topic.asp?t=1050474
Dario -
http://wiki.ross-tech.com/wiki/index.php/01314
http://wiki.ross-tech.com/wiki/index.php/01130
Stu...
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: March 08, 2012, 07:20:35 am »
The repair kit used to be around the 200 quid mark.  I've got to do one on an A3 so I will check the price I can get them for.
Follow AKS tuning on Facebook
Offline CarrG
« Reply #4 on: March 08, 2012, 07:32:14 am »
I've had the same issue with my Touran for a yr now. Cheapest fix all in I found was £450.
VW originally said they would pay 75% then reverted back saying it was 2mths out of warranty   :fighting:
Even after several visits and a letter to HQ no joy! I even suggested timming belt and service at same time to sweet talk them. No chance! I've just left the light on!
K1 Revo 2+
Ibis RS3
