Author Topic: Which one to buy BWA/AXX??  (Read 24919 times)
Offline Grande_GTi
  • -Given: 41
« on: March 20, 2012, 03:04:20 pm »
After noon Gti peeps
Im now looking for a replacement to my previous car, Ive been searching the web and it seems that I should be able to buy Golf GTI quite comfortably upto £7k around 05/56 plate
I know from the MK4 days that certain engines were more easily tuned so the question Im asking out of the 2 engines that are in question BWA & AXX is there a better one to buy?? whats the pro's and cons?? etc
Also when looking at MK5 GTi's to buy what should I look out for??
Thanks in advance peeps
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline reflex11
Offline dan930
  • -Receive: 56
Re: Which one to buy BWA/AXX??
« Reply #2 on: March 20, 2012, 05:00:02 pm »
So what's the difference between AXX&BWA engines?why is one of them more tuneable??
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Saintsteve
« Reply #3 on: March 20, 2012, 05:23:35 pm »
Ed30, best engine out of the lot, from 56 plate onward  :happy2:
AXX is the 1st run engine, had a few fuel pump follower failures + noisy cam chains I would go for the BWA or if funds stretch, as I said, Edition 30.BYD
« Last Edit: March 20, 2012, 05:26:58 pm by Saintsteve »
Offline reflex11
« Reply #4 on: March 20, 2012, 06:08:06 pm »
wasn't the AXX cam followers good and the later models mostly had the cam follower problems
Saintsteve
« Reply #5 on: March 20, 2012, 07:01:11 pm »
No     :signLOL:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: March 20, 2012, 09:52:52 pm »
Wrong way round buddy. VW put harder cams in the BWA
Offline ukdub
« Reply #7 on: March 21, 2012, 09:59:32 am »
Well my 2005 AXX came with the harder revision 'B' where Awesome's BWA (2007)car had the soft revision 'A' cam and was replaced under warranty after the HPFP destroyed it.
Ive not read anything anywhere to suggest that the AXX came with anything other than the 'B' revision cam.  It is strange though that an earlier engine (AXX) would have a later revision part than the newer (BWA) engine
« Last Edit: March 21, 2012, 12:29:52 pm by ukdub »
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
