Author Topic: TDI 140 brake upgrade 288mm to 312mm  (Read 9764 times)
Offline skard
  • -Receive: 245
« on: April 12, 2012, 03:12:31 pm »
I know there's a few threads on this but wanted to clarify...
Running out of retrofits to do so looking at changing the brakes, I have found some front carriers from a GT170, I take it these are 312mm? Is it just a case of swapping these out then adding 312mm discs?
I want to keep the original calipers to make it as simple as possible.
Also looked on ETKA and the dust shields for 288 and 312 have the same part number - did you guys who've done this mod keep your existing dust shields?
Finally, is it the same for upgrading the rears - carriers, dust shields and discs? Does anyone know the sizes of GT170 rears as they guy has all the carriers available.
Sorry for all the questions.
David
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: TDI 140 brake upgrade 288mm to 312mm
« Reply #1 on: April 12, 2012, 05:27:56 pm »
Over the top mod list ;o)
Offline skard
  • -Receive: 245
« Reply #2 on: April 12, 2012, 05:47:21 pm »
Excellent, so it's just carriers + discs for both front and rear?
Offline Phil Miller
  • -Given: 86
« Reply #3 on: April 12, 2012, 05:56:25 pm »
carriers on the front, as for rears dont know as i just bought BERGs GTI rears complete and fitted them
Offline skard
  • -Receive: 245
« Reply #4 on: April 12, 2012, 06:07:48 pm »
Is there any actual benefit other than aesthetics to putting 312mm discs on, seeing as the pad remains the same?
Not sure now as I remembered why I didn't do this before - my M&S winters won't fit anymore being 15s.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: April 12, 2012, 06:20:25 pm »
i'm not the best at physics, but i'd imagine that because even tho the hydraulic pressure and contact area are the same, because the force is being applied a further distance from the centre more stopping force is being exerted.
only comparable example i can think of is this:
try push a door right by the hinges. then push the same door on the edge furthest away from the hinges - it's easier the second time becase you're applying more force to the pivot (hinges) by pushing further away. I'd imagine it's a similar thing.
PLANS: Stage 2+
  • -Given: 243
  • -Receive: 155
« Reply #6 on: April 12, 2012, 06:49:13 pm »
I just told you so, and look at the pictures of front and rear, red caliper carriers and non painted calipers, says it all IMO  :signLOL:
  • -Given: 243
  • -Receive: 155
« Reply #7 on: April 12, 2012, 06:50:37 pm »
You're absolutely right  :notworthy:
Offline skard
  • -Receive: 245
« Reply #8 on: April 12, 2012, 08:34:02 pm »
Thanks guys.
A kind member is sorting me out with front carriers so will get on with this in a few weeks.
Offline A1dan2.0tdisport
« Reply #9 on: April 13, 2012, 10:03:23 am »
Skard, like the idea could you update on price of parts when you have done it? Something I always like doing upgrading brakes.
:D
Offline daboy3000
  • MKV GT TDi
« Reply #10 on: April 13, 2012, 10:39:22 am »
I want to do this too, maybe we could all get some kind of deal.
Offline skard
  • -Receive: 245
« Reply #11 on: April 13, 2012, 11:30:47 am »
I had my eye on some carriers from eBay but getting the front sorted by another member, and I see new Mintex discs on eBay for £55, so a fairly cheap upgrade. Hoping my mrs' Altea takes the 288mm setup and not 280 as my discs are still shiny.
Will probably do the rears in time, more mk5's and similar appearing in scrappies now so should be easier to get carriers.
