Author Topic: Power cut at 4000rpm  (Read 5129 times)
Offline Dan.b
« on: June 02, 2012, 07:24:04 pm »
Hi all,
Just got my mk5 GTi and have a power issue.
If I floor it in 1st or 2nd it splutters at 4000rpm, the rev counter goes dead, EML and EPC light come on. If I then slow down and shift before 4000rpm it seems fine.
Scanned it for fault and found 1 pending fault p0321.
Would I be right in saying the engine speed sensor (G28) could be at fault?
Anyone experienced/ fixed this fault before?
Offline edd666999
  • -Receive: 89
Re: Power cut at 4000rpm
« Reply #1 on: June 02, 2012, 07:47:26 pm »
Had your coil packs replaced under warranty?
Is your car modified?
Did the error come back after being cleared?
Offline Dan.b
« Reply #2 on: June 02, 2012, 08:11:45 pm »
Mines a 2007 and according to VW they dont need doing?
Fault code hasn't come back yet but car still does it.
It runs fine aslong as I don't hold 1st and 2nd Upto 4k + revs
Offline edd666999
  • -Receive: 89
« Reply #3 on: June 02, 2012, 09:21:25 pm »
is the car standard?
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: June 02, 2012, 09:43:09 pm »
Spark plugs?
Diesel Daily Hack.
Offline Dan.b
« Reply #5 on: June 02, 2012, 10:04:48 pm »
Car is fully standard. 42k miles.
Full service inc plugs, cambelt and water pump at 38k.
Google is saying G28 sensor which is the  Engine speed/cam sensor.
Offline Dan.b
« Reply #6 on: June 02, 2012, 10:14:25 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,38163.0.html
Same faults as this guy!
Just wondered if that will cure it.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: June 03, 2012, 08:53:56 am »
Did they actually change plugs though, Breeze VW were supposed to have changed mine, but a month later I was having a bad missfire as soon as it came on boost, and that was the plugs...
Need to scan it... though plugs won;t show as a fault...
Diesel Daily Hack.
Offline Dan.b
« Reply #8 on: June 03, 2012, 09:34:12 am »
I don't think it's plugs. Its not really a misfire. More like a power cuts both mechanical and electrical lol.
I think il change the G28 if I can find out where it is!
Offline Dan.b
« Reply #9 on: June 03, 2012, 04:44:59 pm »
Just been out in it again. The fault happens in any gear at exactly 4000 rpm.
It gets to 4000 rpm then the power cuts, rev counter drops so I shift up and the power is back until 4000 rpm again.
Atleast in saving petrol I suppose lol.
Offline Dan.b
« Reply #10 on: June 04, 2012, 04:49:50 pm »
Just done a 40 mile trip and fault has gone!
Will have to keep my eye on it.
Offline Dan.b
« Reply #11 on: June 10, 2012, 09:22:59 pm »
Fault is happening again intermittently so I will be plugging it in again tomorrow.
Kind of hoping it comes up with G28 sensor as it should be a simple fix!
Offline Dan.b
« Reply #12 on: June 16, 2012, 12:31:21 am »
Problem solved with new crank sensor.
