Author Topic: Revo Stage 2 Software for the 2.0TFSI K04 Based Cars  (Read 37092 times)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« on: May 23, 2009, 11:27:08 pm »
Why: -
For me in simple terms it is the only real way to extract the potential from a modern car by changing a number of parameters within the ECU, effectively provides the best "bang for buck" as our american cousins say  :grin:
This review is related to the Stage 2 version of the Revo software which takes advantage of the Turbo Back Milltek exhaust system I also have fitted to my car. The only other performance modification I am running is a high flow panel filter at present.
As some will be aware I previously had the Superchips Stage 2 software installed which I was generally happy with, but after a trial of the Revo software I found it delivered more than I was expecting, plus with the possible future availability of the a DSG remap from Revo I felt it was the right thing to do to give me a better upgrade path for the future.
I was also very interested in the Select Plus Switch Revo offer as an option with their remaps. A brief list of features from the Revo website which shows the available options this allows you to modified/change: -
  • stock and performance switchability
  • octane specific settings
  • anti-theft mode
  • variable boost and timing settings
  • user presets
My alternative theory behind why is that it's because Revo put something in the coffee machine to make everyone who ventures into their office in Daventry want to buy their Remaps  :laugh:
Sourcing: -
My Revo Stage 2 software was directly supplied by Revo
Revo Technik Limited
47 Brunel Close
Drayton Fields Industrial Estate
Daventry
Northants, NN11 8RB
Tel: +44 (0)1327 301901
Sales: sales@revotechnik.com
Web: www.revotechnik.com
Alternatively they have a network of dealers, list is available on their website   :happy2:
Installation: -
Carl @ Revo completed the installation of the software, this involved re-flashing the ECU via the OBD-II port (a standard way for remaps to be applied to the car) and took probably no more than 10 minutes.
Once complete I was handed the key and asked to take the car for a spin so Carl could complete some data logging with the laptop.
Getting in to the car it immediately felt a bit more alive as I pulled out of the industrial estate where Revo are based but initially thought this was the normal "post modification placebo effect".
However after completing the first logging run I knew the car was pulling much stronger and reached the legal speed limit (and not 1 mph over) of the chosen test road much quicker than before.
The first run showed the fuel was very good octane (I was running Shell V-Power at the time) and it was nearer the quality they expected from the 100 octane brews you get in places like Greece  :drool:
Also the rate that I cycle through the fuel was thought likely to help as I generally fill up 3-4 times a week  :surprised:
So after a quick stop off to increase the timing and a second run was completed, results showed the cars was running well with no "knock" on the timing.
The Revo setting where configured as follows - B8-T6-F9
We returned back to the Revo office and I knew it was the right decision to take their software.
Carl also prepared a second set of settings on a Select Plus Switch which described as more aggressive which are B9-T5-F9.
So all in the whole process (including being taken for a test drive in their Stage 2+ Leon Cupra Demo Car  :scared:) took 2 hours  :happy2:
Plus Points: -
  • Improved performance and driveability
  • Element of User Switchablity via the Select Plus Switch
  • Proven upgrade path for Stage 2+ for further performance increases
  • Good Customer Service and Knowledgeable Staff
Minus Points: -
  • Just the one, doesn't help the "slippery slope" urges to continue modifying  :laugh:
Summary: -
In summary I was very impressed with the guys at Revo and the passion and knowledge they showed about their product and the world of car tuning.
I have now put around 250 miles on the car of very mixed driving from central London, to motorways, A roads, B roads and country lanes and in all cases the car drives so much better.
It is smoother in traffic and low speed driving and when the conditions allow it is just so much more alive on the road. (In fact typing this review makes me want to go for another drive  :grin:).
The power delivery now seams to be across a much broader band and pull stronger all the way up to the point the DSG gearbox forces the gear change.
Fuel economy has remained the same on the long runs as before, can't say on the around town/cross country roads as I have been experimenting so it's been a bit lower than I would expect   :evilgrin:
You can also hear the additional boost that has been dialed in now too  :drool: :drool:
I haven't used the Select Plus Switch or tried the "Aggressive" settings as yet but will update the thread once I have.
So would I recommend it, 100% YES  :driver: :driver:
The car will be going on a rolling road on the 6th so I will post up the graph shortly after this.  :happy2:
« Last Edit: May 25, 2009, 07:21:37 pm by SteveP »
Re: Revo Stage 2 Software for the 2.0TFSI K04 Based Cars
« Reply #1 on: May 25, 2009, 12:24:41 am »
I know exactly what you mean, Steve - I've had their 'coffee' too! :happy2:
I'm quite surprised you have changed to Revo from Superchips but pleased to read you are so happy.
Offline chungster
« Reply #2 on: May 25, 2009, 08:29:07 am »
Boost 9 setting, are you sure??
Good review tho!
« Reply #3 on: May 25, 2009, 11:03:56 am »
Revo Carl seems to like that boost setting with the K04...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: May 25, 2009, 11:06:44 am »
My bad, his base setting for my car are B8-T6-F9, the aggressive are B9-T5-F9  :smiley:
Offline SteveS
« Reply #5 on: May 25, 2009, 12:33:03 pm »
Dont yo need to have a HFP for stage2?
He said if i liked aggressive to use B7/8.... B9... well... duno what that would be like
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline WhiteGTI
  • F-A-S-T
« Reply #6 on: May 25, 2009, 12:46:59 pm »
^^ HPFP is required for "Stage 2+"  :happy2:
2006 E46 BMW M3 - 343hp
Offline SteveS
« Reply #7 on: May 25, 2009, 01:21:32 pm »
ooo
SOLD!! :(
« Reply #8 on: May 25, 2009, 01:32:44 pm »
I run boost 9 all the time LOL
Offline Sunglasses Ron
« Reply #9 on: May 25, 2009, 02:01:34 pm »
Cracking review Steve and welcome to the dark side mate.. Niice choice :happy2:  Oh and thanks for making me miss my car even more now too  :signLOL:
So when is the pump being installed for the Stage 2+?  :wink:
« Last Edit: May 25, 2009, 02:04:01 pm by Vtec Abuser »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #10 on: May 25, 2009, 07:23:33 pm »
^^ Cheers Ben, I thought you might be along  :laugh: :laugh:
I will run stage 2 for a bit but the Stage 2+ is on the cards for the future  :evilgrin:
Just need to get back the Santa Pod to see how she goes down the strip now  :driver:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #11 on: May 25, 2009, 09:51:46 pm »
nice one Steve  :happy2: have you logged to check the boost levels in comparison to SC?
look forward to the RR plot  :laugh:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #12 on: May 25, 2009, 11:03:24 pm »
What is your best so far on the 1/4 mile (as a benchmark)? :smiley:
« Reply #13 on: May 26, 2009, 09:23:27 am »
Think Steve has done a 13.8 IIRC but i'm sure he'll confirm shortly..
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #14 on: May 26, 2009, 09:55:05 am »
Correct  :happy2:
