Author Topic: clima tronic secret menu veiwing procedure.....golf gti mk5  (Read 72919 times)
Offline RSM
Yup. Correct. You can get all those features from your climatronic by doing this procedure :
Hold down "econ" button, and press the up vent (next to recirculate). Both temp displays will read 00 or 00 0, and you can release the buttons once they do.
Twist the LEFT temp knob clockwise until it reads 19 0.
Twist the FAN knob unti the left temp reads 19 1 (like 19.1).
The right temp display is now a digital speedometer!
For Tachometer turn FAN clockwise untill it reads 19 3.
to cancel just hit the "econ" button again.
This is what the rest of the numbers mean
Main channel: 0 - System data
0 Number program
1 Left ERL
2 Skillful ERL
3 Point of job accensione/avvio
4 I recirculate automatic rifle (motor)/I recirculate automatic rifle Bit
5 Heating from active detention
6 Air Quality (7 = fresh air)
7 Deriving
8 Acronym country
9 Sensor zone head
Main channel: 1 - UIF
0 Inner temperature (°C)
1 Surface Temperature (°C) (I think it means external)
2 Temperature piastrine in platinum (°C)
3 Corrector piastrine in platinum (°C)
4 Uif-Sonnenint
5 Corrector radiation (°C)
6 dynamic corrector (°C)
7 OrrettoreC I recirculate (°C)
8 thermal corrector (°C)
9 Compensation ignition (°C)
Main channel: 2 - Sensor radiation SX
0 Radiation not delayed (W/m2)
1 Corrector radiation for regolator temperature (W/m2)
2 Corrector radiation for impeller (W/m2)
3 Value TO
Main Channel: 3 - Sensor radiation DX
3 Value TO
Main Channel: 4 - External Temperature
0 External temperature (°C)
1 Temp. External line CAN (°C)
2 Temperature inhaled air climate (°C)
Main Channel: 5 - Theoretical temperature SX
0 Theoretical Temp. air in escape SX (°C)
1 Theoretical difference between temp. and temp. effective (°C)
2 Value regulation the sx. (½% )
3 Pi-Stell-Max (½%)
4 Defrost SX
Main channel: 6 - Found temperature SX
0 Temp. Found SX (°C)
1 Temp. Feet SX (°C)
2 Temp. Facade SX (°C)
Main channel: 7 - Theoretical temperature DX
0 Theoretical Temp. air in escape DX (°C)
1 Theoretical difference between temp. and temp. effective DX (°C)
2 Values of regulation regolator (½% )
3 Pi-Stell-Max (½% )
4 Defrost
Main channel: 8 - Found temperature DX
0 Found Temp. air in escape DX (°C)
1 Temp. Feet (°C)
2 Temp. Facade (°C)
Main channel:9 - Theoretical temperature evaporator
0 Theoretical temperature evaporator (°C)
1 Theoretical difference between temp. and temp. effective evaporator (°C)
2 Values of regulation evaporator (5mA/Dig)
3 Modality Regolator evaporator (you see under)
Main channel: 10 - Effective temperature evaporator
0 Effective temperature evaporator (°C)
1 Pressure coolant climate (bar)
2 Medium temperature coolant climate (°C)
Main channel:11 - Climate control compressor
0 Power theoretical electrical worker
1 Power effective electrical worker
2 Power electrical worker max
3 Kompressor PWM (0... 200) (Dig)
4 Power electrical worker offset compressor
5 Values power electrical worker
6 Code disinserito compressor (you see system)
Main channel:12 - Climate control impeller
0 Theoretical tension of the electric impeller (V)
1 Manual regulation
2 Code anomaly
3 Reduction impeller (V)
4 Impeller offset (0.1V)
Main channel: 13 - Temperature bocchette air SX
0 Formattato theoretical value (%)
1 Real theoretical value temp. Bocchette sx.(Dig)
2 Confirmation el. temp. Bocchette sx (Dig.)
3 The maximum limit temp. Bocchette sx. (Dig)
4 Limit min. temp. Bocchette sx. (Dig)
Main channel: 14 - Temperature bocchette air DX
1 Real theoretical value temp. Bocchette dx (Dig)
2 Confirmation el. temp. Bocchette dx (Dig)
3 The maximum limit temp. Bocchette dx (Dig)
4 Limit min. temp. Bocchette dx. (Dig)
Main channel: 15 - Piedi/centrale temperature bocchetta
1 Real theoretical value temp. Bocchetta centers them (Dig)
2 Confirmation el. temp. bocchetta centers them (Dig)
3 The maximum limit temp. bocchetta centers them (Dig)
4 Limit min. temp. bocchetta centers them (Dig)
Main channel:16 - Defrost Shovel
1 Theoretical value real Defrost shovel (Dig)
2 Confirmation el. Defrost shovel (Dig)
3 Limit maximum Defrost shovel (Dig)
4 Limit min. Defrost shovel (Dig)
Main channel: 17 - Shovel I recirculate inner
1 Theoretical value real shovel I recirculate (Dig)
2 Confirmation el. shovel I recirculate (Dig)
3 Limit maximum shovel I recirculate (Dig)
4 Limit min. shovel I recirculate (Dig)
Main channel: 18 - Shovel cold air
1 Theoretical value real Shovel cold air (Dig)
2 Confirmation el. Shovel cold air (Dig)
3 Limit maximum Shovel cold air (Dig)
4 Limit min. Shovel cold air (Dig)
Main channel: 19 - Data Motor
0 Vehicle velocity (km/h)
1 Vehicle velocity (Mph)
2 Motor temperature (°C)
3 Engine speed (RPM)
4 Air con compressor speed (RPM)
Main channel: 20 - Data sent by CAN
0 Additional heating (upon request) (1 = on)
1 Confirmation el. PTC (1 = on)
2 Power el. effective PTC
3 % air demanded from radiating climate (%)
4 Relationship % of radiating peak air (%)
5 No performance demanded to the disp. of heating (1=no performance heating)
Main channel: 21 - Ripartitore of air Climate
0 Defrost (%)
1 Facade (%)
2 Feet (%)
3 Bocchetta areazione (%)
4 I recirculate fresh air/cleaned up (+ bocchetta...) (%)
5 Appraisal sensor (%)
Main channel: 22 - Data timer
0 Period of pause (min)
1 Motor operating time (sec)
2 Operating time with inserted key (Sec)
Main channel: 23 - Special channel
0 Sensor inner lighting system (Dig)
1 Air quality sensor
Main channel:24 - Version software
0 Development state
1 Software version
2 Type SW
3 Keep Frozen (0/1 = Values of refrigeration come maintained ad.eccezione.della Diagnosis )
4 Version K Matrix
5 EEP- Testflags
6 It codifies Vag (2)
Main channel: 25 - Test channels
1 - 9
Main channel: 26 - Parameters for surveys on crystals
0 Delay (sec)
1 Passo/udm (digit)
2 The minimal limit (digit)
3 Limit max. (digit)
4 Passo/udm on HellaKit
Main channel: 26 - Bocchetta direct areazione
1 Theoretical value real Bocchetta direct areazione (Dig.)
2 Confirmation el. Bocchetta direct areazione (Dig.)
3 Limit max. Bocchetta direct areazione (Dig.)
4 Limit min. Bocchetta direct areazione (Dig.)
Main channel: 28 - Umidita
0 Theoretical Umidita (%)
1 Relative Umidita on temperature UIF (%)
2 Temp. Crystals WSS (°C)
3 Temperature condensation point (°C)
4 Difference temperature of the melting point (°C)
Main channel: 29 - Crude values umidita
0 Temp. Crystals, corrected (°C)
1 Temp. Crystals, not corrected (°C)
2 Sensor umidita (%)
3 Temperature sensor (°C)
4 Temperature condensation point (test measure) (°C)
5 Code anomaly
Main channel: 30 - Values indicated to you umidita
0 Value sensor termofilo (Dig.)
1 Temperature rif. termofilo (Dig.)
2 Periodic duration umidita (10 (to the power of -4) sec)
3 Temp. Reference umidita (Dig.)
4 Umidita Rel. on the sensor (%)
5 Temperature sensor umidita (°C)
6 Temperature crystals (not corrected) (°C)
 :drinking:
RSM
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: clima tronic secret menu veiwing procedure.....golf gti mk5
« Reply #1 on: July 06, 2012, 12:24:17 pm »
Thanks for posting up the correct "secret menu" combinations, there are so many people on here believing this menu will tell you oil temperature, boost pressure etc.
 :notworthy:
Offline RSM
« Reply #2 on: July 06, 2012, 12:58:45 pm »
 :notworthy:
No Probs........
RSM :happy2:
Offline ReflexRob
« Reply #3 on: July 12, 2015, 05:08:04 pm »
Tried this the other day, both mph and kmh figures were miles off. Anyone else experienced this?
Offline patpong_pete
« Reply #4 on: July 13, 2015, 12:47:35 am »
does this secret work on mk 6 climate or only mk5
thanks for info and reply
Offline john87
  • -Receive: 53
« Reply #5 on: July 13, 2015, 09:53:59 am »
I don't think the mk6 has the digital readouts therefore this wouldn't be possible?
leftloui7
« Reply #6 on: January 17, 2018, 07:02:07 pm »
One question..Does this trick work on the b6 Passat with the climatronic aircon?
Sent from my you've been hacked using Tapatalk
