April 02, 2025, 03:55:10 am
All Things Mk5
Cosmetic/Interior Modifications
Footwell lights
Topic: Footwell lights (Read 3927 times)
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
All donations accepted, thanks.
Footwell lights
May 27, 2009, 05:29:12 pm »
Howdy.
Does anybody know how to remove the little interior lights that are in the front footwell? I wanna sort it so they light up red to match the other interior illumination.
Cheers.
JPC
Just look at my post count
-Given: 93
-Receive: 111
Re: Footwell lights
Reply #1 on:
May 27, 2009, 05:41:56 pm »
they are plastic clips that need prying out. pretty easy to be honest.
take out the standard bulb and put a red LED, jobs a good en
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
Re: Footwell lights
Reply #2 on:
May 27, 2009, 05:51:06 pm »
Hmmm. I've tried to push them out and they don't seem to want to budge? I can't see any clips round the back either? Are the same on all mk5's or have they been revised maybe.........or am I just being dense!?
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
Re: Footwell lights
Reply #3 on:
May 27, 2009, 05:59:12 pm »
SORTED! Ta.
stealthwolf
-Given: 306
-Receive: 292
ED30 No.1412
Re: Footwell lights
Reply #4 on:
May 28, 2009, 12:32:19 am »
^^^How'd ya do it?
The
GTI
isn't just a machine. It's very much a living, breathing thing.
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
Re: Footwell lights
Reply #5 on:
May 28, 2009, 08:59:00 pm »
Basically theres a small clip that on the side closest to the door. If you just gently pull it at this side first the clip just pops out and then the other side will follow. Just disconnect the electrical connector by pinching the sides and the whole unit comes away nicely.
Once its out the clear plastic bit sits in a metal case by the way of 4 x very small clips, one in each corner. I just used a fine screwdriver to pop it out and then the bulb just slips out.
The below link takes you to somewhere that sells the bulbs in red or MAPLIN Electronics do them in blue if you'd prefer.
http://www.ultimatestyling.com/products/details.mhtml?code=2869
stealthwolf
-Given: 306
-Receive: 292
ED30 No.1412
Re: Footwell lights
Reply #6 on:
May 29, 2009, 12:10:21 am »
Any pics?
I wanted sub lighting in the car. Not sure how I'd do it but this sounds like a step forward.
The
GTI
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
Re: Footwell lights
Reply #7 on:
May 29, 2009, 06:16:28 pm »
When my bulbs arrive I'll be taking them back out to swap the bulbs over. When I do I'll take some pics and post them on this thread.
big al
-Given: 27
-Receive: 93
Re: Footwell lights
Reply #8 on:
May 31, 2009, 11:01:50 pm »
i changed mine this morning, pretty easy to do actually, have not seen them lit up at night yet, and you can hardly see them in the day, but I think thats the same with the standard ones.
Boothy
Won't Shut up.
-Given: 24
-Receive: 32
Re: Footwell lights
Reply #9 on:
June 01, 2009, 05:50:31 pm »
They look
when its dark. I bet the blue would too. Then they'd match the other interior lighting instead.
All Things Mk5
Footwell lights
