Author Topic: Urgent RCD510 Wiring help  (Read 12528 times)
Offline JStav
    • Facebook
« on: October 13, 2012, 03:33:23 pm »
Hi guys I know this is not the right section but I need urgent help so was hoping this would attract more attention.  I'm in desperate need of help as currently my car interior is all over the place and I need to use the car later (idiot me for assuming I'd fix it easily!)
I've tried to fix my aux interference issue today and now not only have I not fixed that but the CD option on the unit is greyed out!?  Have I broke it? :scared:
I read it was a black connection you had to move from pins 2 - 3 however the only connection in 2 was a blue cable!?
That's the main connection I have.
That's the connectors from the aux which are in the following:
1 - Nothing
2 - blue (although it does appear there is some black sheath further down on it)
3 - Nothing
4 - Nothing
5 - Nothing
6 - Black
7 - Nothing
8 - White
9 - Pink
10 - Yellow
11 - Green
12 - Red
Assuming I'm reading it the right way or could it be the opposite way round and 1 is in fact red!?
Does anyone have any idea how I can not only fix the interference but also what the hell has happened to my cd option? :(
Any help will be greatly appreciated and I will be eternally grateful!
Silver GTI, Revo Stage 1, R32 rear bumper, R32 exhaust, R32 rear lights, ED30 front splitter, RCD510, Lowered on Eibachs, open fog grills.
Re: Urgent RCD510 Wiring help
« Reply #1 on: October 13, 2012, 07:23:22 pm »
You really need to post a pic of your pin out diagram at the top of the unit.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: October 13, 2012, 07:36:27 pm »
Pin 2 into Pin 3
Cluster and Key coding
Location Great Yarmouth
Offline JStav
    • Facebook
« Reply #3 on: October 13, 2012, 07:38:00 pm »
Also it's an "Ipod connection kit" that was fitted by VW Lookers in Teesside.
Any help is greatly appreciated
Offline JStav
    • Facebook
« Reply #4 on: October 13, 2012, 07:39:42 pm »
Pin 2 into Pin 3
Hi Eddie, thanks for the reply!
I tried this and I got absolutely no sound from AUX.  :confused:
Any idea on why the CD option is also greyed out?
Offline mb
  • -Receive: 29
« Reply #5 on: October 13, 2012, 08:30:06 pm »
I think it's the other way round where pin 1 is the red wire so yellow & green need swapping over.
If you have moved the blue wire then that might be something to do with the cd so as the wire has been moved its not getting a signal so greyed out the option?
Offline JStav
    • Facebook
« Reply #6 on: October 14, 2012, 02:02:03 pm »
Cheers for the advice MB.  Tried that to no avail as well.
Now I have a RCD510 that is only good for the radio as the cd option isn't there anymore  :sad1:
Gutted isn't the word :(
« Reply #7 on: October 14, 2012, 04:27:09 pm »
Is that pin out for your rns510?
What unit did your car originally come with? You really want the pic of that unit's pin out to compare with the rns510 to determine how to position/move the connector plug wires.
Offline JStav
    • Facebook
« Reply #8 on: October 15, 2012, 12:18:56 pm »
That's the pin out for my RCD510.  As far as I'm aware the Ipod connection kit was fitted to the RCD510 and not a previous unit.
« Reply #9 on: October 15, 2012, 02:54:32 pm »
Is your ipod connection under the armrest?
What was the original unit in the car, rcd 300 or rcd500?
I'm confused why you don't have a black wire in either pin 2 or pin3 as they are ground wire pins for the rns510 for cd and aux in. Don't know why you've got a blue wire at pin 2. Did you swap wires around then take the pic?
« Last Edit: October 15, 2012, 03:10:01 pm by bacillus »
Offline JStav
    • Facebook
« Reply #10 on: October 15, 2012, 03:06:18 pm »
The original was the RCD 300.  The output came directly from behind the head unit and out of the interior trim near the ash tray.  Just a simple headphone jack.
« Reply #11 on: October 15, 2012, 03:14:38 pm »
See my revised post above.
Do you still have the rcd300 as posting a pic of the pin out diagram may help sort this out. I suspect it's similiar to a rcd500 but not sure.
Offline JStav
    • Facebook
« Reply #12 on: October 15, 2012, 03:21:05 pm »
Hi can I just say many thanks for the help it's greatly appreciated.  I don't have the RCD300 I'm afraid the car came with the RCD510 already in and the AUX input.
I have found this though if it will be of any use to you?
Edit:  Just to say that's exactly how the cables were before I moved anything.  All I tried was moving the blue cable from 2 --> 3 and not only did I get no sound from the AUX but my CD option is now greyed out as well.
« Last Edit: October 15, 2012, 03:24:40 pm by JStav »
« Reply #13 on: October 15, 2012, 03:36:37 pm »
Is it possible/easy to check to see if the blue pin 2 wire is really originating from your aux input? If so, what colour is the other wire from it?  Just speculating that it's wired incorrectly.
Offline JStav
    • Facebook
« Reply #14 on: October 15, 2012, 03:50:28 pm »
That whole black connector with all the wires is the AUX input.  It's the connector end that goes into the back off the RCD 510.  The other end is a black box with a headphone jack socket from which a headphone jack cable comes out that I can plug into a phone etc.
