Author Topic: Vag com help Fleet hampshire  (Read 1263 times)
Offline Jonathon555
« on: November 14, 2013, 07:14:08 pm »
My mate has just got a new 2013 A4 , he needs some help enabling video in motion in his car.
Can anyone recommend anyone who he can drop a few quid to, to get it enabled ?
Thanks for any help
Saintsteve
Re: Vag com help Fleet hampshire
« Reply #1 on: November 14, 2013, 07:16:28 pm »
Pm Hedge  :happy2:
Offline Jonathon555
« Reply #2 on: November 14, 2013, 07:25:46 pm »
Ok will do :happy2:
« Reply #3 on: November 14, 2013, 07:39:56 pm »
You can't do VIM with VCDS.
« Reply #4 on: November 14, 2013, 07:46:41 pm »
 :evilgrin:
Offline Jonathon555
« Reply #5 on: November 14, 2013, 08:01:41 pm »
Pm sent
Offline Thor
  • -Receive: 25
« Reply #6 on: November 14, 2013, 09:42:07 pm »
I think you can use VCDS on the latest Audi's
see below - from this page http://www.vwaudiforum.co.uk/forum/showthread.php?132245-A6-C7-VCDS-Tricks  i know its for the A6 C7 but from the little i've read i think the architecture is similar.  :happy2:
7. VIM
Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
I used the same technique as in my C6 with MMI 3G. These are the steps I followed:
[Select]
[5F-Information Electr.]
[Advanced ID - 1A]
Make a note of the Serial Number
Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
Follow the link for MMI 3G
Enter your serial number into the input field
Make a note of the personal login code and the alternative login code it returns
[Security Access - 16]
Enter your personal login code.
[Do it!]
If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
[Adaptation - 10]
Select channel 48
Press read
Set the value from 0 to 255
Press test
Press save
Press "Done, Go Back"
Close VCDS and reboot your MMI as detailed in step 5 above
This works as expected.
                                     Mk6 GTI
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #7 on: November 14, 2013, 09:51:18 pm »
Thanks for any help
What DVD player is he using Jon, is it an OEM one?
I've not yet found an OEM RNS-E that plays regular DVD's, the DVD player is simply there to read the Map DVD's (unlike the RNS510 which is a much more versatile DVD player).
I don't know whether this is a hardware or software limitation, but either way I expect he'll have to do something for it to play DVD's in the first place if it's an early 2013?
My 2012 RNS-E LED in my A3 2010 won't do anything with region 2 film DVD's as we know them  :chicken:
Pete
Offline Jonathon555
« Reply #8 on: November 15, 2013, 07:43:58 am »
Thanks for any help
He has the latest Audi MMi system october 2013 Audi A4 Sline black edition
