Author Topic: Exhaust warning light - update: problems! - RESOLVED!  (Read 6458 times)
« on: September 16, 2009, 09:22:37 pm »
Managed to get the warning light for the exhaust come up today for the first time. Car's been fine, with no unusual changes in the last few days or so. It didn't come up this morning when I went to work but came on an hour later when I had to go somewhere else.
No obvious changes in the characteristics of the car.
Sooo....did a VCDS scan (posting just the relevant bits):
Wednesday,16,September,2009,20:31:33:53997
VCDS Version: Release 908.0
Data version: 20090830
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: xxxxxxxxxxxxxxxxx   Mileage: 17000 miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: xxxxxxxxxxxxxx
   Coding: 0403000318070160
   Shop #: WSC 24006 576 00000
2 Faults Found:
004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
               P129F - 001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:22:16
             Freeze Frame:
                    RPM: 944 /min
                    Load: 22.0 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
               P310B - 001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage:
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:08:19
             Freeze Frame:
                    RPM: 776 /min
                    Load: 20.4 %
                    Speed: 5.0 km/h
                    Temperature: 56.0°C
                    Temperature: 19.0°C
                    Voltage: 14.351 V
Readiness: 0000 0000
Looking these up alludes to problems with either the fuel pressure sensor itself or the pump (or both!).
Anyone had a similar problem come up? How long did it take to sort?
« Last Edit: September 25, 2009, 10:56:55 pm by stealthwolf »
Re: Exhaust warning light
« Reply #1 on: September 16, 2009, 09:50:23 pm »
Have you had your the fuel pressure sensor changed?
btw you should update your vcds to the release dated 11-09-09
« Reply #2 on: September 16, 2009, 09:59:56 pm »
Nope. Other than an air filter change, car has been unmolested since I bought it 12 months ago.
« Reply #3 on: September 16, 2009, 10:39:21 pm »
Not remapped either?
« Reply #4 on: September 16, 2009, 10:48:51 pm »
I think you need to get the fuel pressure sensor changed in the first instance if you don't want to use the dealer for whatever reason.
« Reply #5 on: September 16, 2009, 10:56:06 pm »
No mate. Car is unmodified because of insurance issues. Once I switch to a mod-friendly insurer, it'll be mods-galore.
Will definitely go down to the dealers this weekend but wanted an idea of what was likely to be causing issues and an idea of time/cost. Need the car for work, so wouldn't be happy about being car-less!
Offline Poppa Dom
« Reply #6 on: September 16, 2009, 11:21:16 pm »
95% sure that this is the fuel pressure sensor thaton the low pressure side of the HPFP. There is a TSB on this - TSB 24 07 08 June 19, 2007 2015106/1 (not sure if just US market). Fine to drive until sorted  :happy2:
Dom
« Reply #7 on: September 16, 2009, 11:32:43 pm »
Hmmm...surprised about that because I'm sure my build date was October 2007 or thereabouts.
Offline no golf clubs at all
« Reply #8 on: September 17, 2009, 10:48:58 am »
I had this lamp on, took it to an Indy who checked the codes, sorry that I didn't record the codes now. But he cleared it and it has never came back. I remember the lamp coming on, I was sitting at lights in S with my foot on the brake (something I never do).
Anyway it's been ok for 4 weeks and apparently this lamp can come on for any number of reasons.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #9 on: September 17, 2009, 10:58:32 am »
Has the ecu had an update?
Clear the fault codes and see how you get on.
My car had 12 fault codes once, and intermittently ran like sh*t. Cleared fault codes, updated ecu softare and its all been fine since. And this is on a 09 car.
Offline tony_danza
  • -Receive: 112
« Reply #10 on: September 17, 2009, 11:34:21 am »
I had that sensor replaced on a recall - 09/06 build.
EDIT: recall notice 24m5. no letter received, just advised when it was in for the DSG check.
« Last Edit: September 17, 2009, 11:41:02 am by tony_danza »
Sideways yo!
« Reply #11 on: September 17, 2009, 06:08:04 pm »
Not it's not had an ECU update as far as I'm aware. It had it's first service (oil change) back in January. No mention of ecu update at the time. Like I said, it's been fine since I bought it in Aug 08.
« Reply #12 on: September 18, 2009, 09:15:12 pm »
Gah! Stealers say they can't fit me in for a diagnostic until tuesday and that it'll take an hour!
What's the difference between the dealers and vcds?
« Reply #13 on: September 18, 2009, 09:23:28 pm »
About 60 squid.  :innocent:
« Reply #14 on: September 18, 2009, 09:56:21 pm »
