Author Topic: *** All your Revo question's and answer's in here please. ***  (Read 43301 times)
Offline SteveS
Re: revo users - select plus?
« Reply #165 on: March 07, 2009, 09:14:57 pm »
ah, shame, bit far for me tomorrow..
Distance: 132.25 miles, about 2 hours 27 mins
still in two mines about the switch.. what are the standard settings?
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #166 on: March 07, 2009, 09:16:47 pm »
you should have been given a printout with your settings on  :confused: its about 2 hours for me  :signLOL: to dub show
Offline SteveS
« Reply #167 on: March 07, 2009, 09:17:58 pm »
nope didnt, didnt know everyone did???
ah too far, cant b arsed.. :D
SOLD!! :(
« Reply #168 on: March 07, 2009, 10:23:33 pm »
For 98 octane the default setting is B6 T5 F9.
« Reply #169 on: March 07, 2009, 10:50:32 pm »
I'm not saying don't get a SelectPlus but I wouldn't "experiment" with the settings without being absolutely sure what you are doing. Every individual car is different and it also depends which other performance mods you have.
Offline neg
  • gone old skool
« Reply #170 on: March 07, 2009, 11:14:30 pm »
Read the manual and just be careful not to go too silly - especially with the timing in hotter weather.
The levels you can adjust to are all with the cars limits as long as you know what you are doing.
Plus definately worth it
Offline SteveS
« Reply #171 on: March 08, 2009, 12:17:30 am »
if i dont have vag com then how do i know i can change the settings safely. how do i know what i should put them too.. i guess i can only get advice from you/others that have done it
SOLD!! :(
Offline WhiteGTI
  • F-A-S-T
« Reply #172 on: March 08, 2009, 07:43:26 am »
^^^ Every car is different and will react differently to the settings, so I would not recommend possibly copying another members settings. Although, sure similar principles will apply, so you can take their advice.
I would seek the advice of your tuner. If you feel the need to change the settings, then have a word with them. They should have datalogged your car in the first place to set it up with the correct settings, so they should have an idea regarding what a change would do to the car.
But as people have said, ideally you would want VCDS whenever you want to make a change.
2006 E46 BMW M3 - 343hp
Offline neg
  • gone old skool
« Reply #173 on: March 08, 2009, 08:19:24 am »
Others can give you an idea of what is 'best' but if you then wanted to play further than this you have to take other things into consideration - mods/ambient temp/weather etc and VCDS comes into play.
I think the default settings were 549 or 449, and the 98RON default was 659 ( I think).  From experience most cars running 98/99RON are ok running upto timing 6, occasionally 7 (but loggin advised just to check, or dont run it for long).  Boost you can generally run what you like but they do work better altered together in most cases.
« Reply #174 on: March 08, 2009, 10:04:54 am »
....Do you really think it's wise to adjust your settings because of what some guy on an internet car forum advised or suggested?
For example, a F9 setting might be better for one car but not for another. It's a complicated balance best left to experts like Revo themselves or their better agents unless you're a pro tuner yourself like Nick of R-Tech.
There are likely to be long term effects if you get it wrong. You don't want to run long term with fuelling too rich or too lean for example. The ECU may protect to some degree but it all has knock-on effects.
The switch is merely a convenience. For example, after a session on JKM's dyno and their study of data later, they might phone to advise me to change a setting without me needing to drive 2 hrs to visit.
« Reply #175 on: March 08, 2009, 10:08:12 am »
....Have you sorted out your turbo problem yet, neg?
« Reply #176 on: March 08, 2009, 10:12:28 am »
.... x 2 - Exactly!
Certainly listen to what others have to say but don't rely on their settings - Consult your tuner.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #177 on: March 08, 2009, 10:20:04 am »
When running a modded car VCDS should be on the purchase list anyway.
The Select Plus is a bargain at that price.
Stu...
« Reply #178 on: March 08, 2009, 11:03:42 am »
....Pointless unless you know what you are doing - You do, I'm led to believe - I don't.
Quite a few people are wannabe tuners and fancy they know but don't really know enough. You appear to know a lot more than most other non-professionals and I, for one, will always listen to your advice. However...
I run a modded car and have no use for VCDS for my own use. I would rather buy you a beer (or whatever) to change my lighting settings or similar via VCDS but I wouldn't let you near my tuning settings even though you have much valuable knowledge. Unless of course you were a Revo or JKM employee.
:smiley:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #179 on: March 08, 2009, 11:10:55 am »
:smiley:
Well so long as you have deep enough pockets to cover your words of wisdom that is fine.  Most don't and they like to know what their car is doing.
When people don't have VCDS and run a modded car is when you get random posts like my CEL came on what is it??
Stu...
