Author Topic: Mk6 climatronic install into mk5  (Read 18883 times)
Offline paulmk5gti
« on: January 24, 2014, 12:24:00 pm »
As above anyone know how to do this I have everything I need.  Just need to know what wiring changes to make :-)
Sent from my GT-I9300 using Tapatalk
Offline SI-R32
  • -Receive: 126
Re: Mk6 climatronic install into mk5
« Reply #1 on: January 24, 2014, 12:26:33 pm »
what year is your car
Offline paulmk5gti
Re:
« Reply #2 on: January 24, 2014, 12:57:28 pm »
56 reg
Offline SI-R32
  • -Receive: 126
« Reply #3 on: January 24, 2014, 01:00:22 pm »
well its doable in your car but you have 2 flaps buried in the heater unit somewhere and the mk6 unit is designed for one flap, but people have done it but may not be exactly like your mk5 unit
have a read through this
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed
and this
http://www.r32oc.com/topic/39962-golf-mk6-climatronic-in-a-golf-mk5-displaying-on-a-rns510/
Offline paulmk5gti
Re:
« Reply #4 on: January 24, 2014, 01:10:03 pm »
Thanks for the info :-)
Offline paulmk5gti
Re:
« Reply #5 on: January 24, 2014, 04:36:15 pm »
All done and working spot on cheers for the advice
Offline Leigh200sx
Re:
« Reply #6 on: February 01, 2014, 08:38:53 am »
Tapatalk
This looks brilliant and a huge improvement over the OEM one. My car is a 2006 and I'm about to do this swap, can I ask you how hard it is? And did it work out of the box or were there complications? I've read I may need a different loom
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #7 on: November 01, 2014, 09:01:46 pm »
I'm about to do this and reading the various how to threads (posted above).
My car is  2006 GT TDI.
Can someone confirm the pin swap on connector A (black), as I've read conflicting information:
Is it:
Extract Pin 16 and Pin 20. Put pin 16 into pin 20 slot, leave pin 20 loose. May have to cut / change the pin connector as its a different size?
(So pin 16 moves to pin 20)
OR
Extract Pin 16 and Pin 20. Cut the end off pin 20. Splice into pin 16, put back into pin 16 slot.
Tape the bare end of 20.
(So 16 & 20 both goto pin 16, pin 20 is now empty).
If that doesn't work, try the swaps mentioned regarding plugs B / C?
@paulmk5gti what did you do, your car is same year as mine so will hopefully be the same.
EDIT: Found the answer in this thread:
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/9170-climatronic-screen-4-print.html
Now to work out the air quality sensor, again it doesnt seem clear on where the 3 pins goto:
Quote
Quality Sensor Wiring (OPTIONAL if you bought the module that handles it):
On C Connector (black):
Pin 1 from Quality Sensor to Pin 20 (which we replaced by Pin 16 on Climatronic, remember?)
Pin 2 from Quality Sensor is Ground goes to Pin 19
Pin 3 from Quality Sensor to Pin 4 on Climatronic
Does this mean:
Pin 1 - connector A Pin 20
Pin 2 - connector A Pin 19
Pin 3 - Connector A Pin 4
 :stupid:
Jas
« Last Edit: November 01, 2014, 09:52:30 pm by jason_rmh »
VCDS (Preston, Lancashire)
Offline Matto
  • -Receive: 116
« Reply #8 on: November 01, 2014, 10:20:27 pm »
All I did was cut both wires 16 and 20 then solder them the other way round. The connectors as mentioned are different sizes so cannot just be extracted from the plug and swapped. My understanding is you leave 20 loose so it can be connected to the air quality sensor but it is not required for the unit to function. It only allows the auto recirc function. All you will get is a fault message in VCDS saying something along the lines of air quality sensor open circuit.
Hope this helps.
« Last Edit: November 01, 2014, 10:26:19 pm by Matto »
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #9 on: November 01, 2014, 10:22:10 pm »
Cheers @Matto. Did you install the air quality sensor? Do the 3 wires run to the same black connector at the panel (connector A)?
Jas
Offline Matto
  • -Receive: 116
« Reply #10 on: November 01, 2014, 10:32:59 pm »
I have the sensor but haven't got round to fitting it. Tbh the thought of being upside down in the footwell trying to feed wires through puts me off but yes the 3 wires feed back to the unit. It does sound from the write they all go into Connector A.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #11 on: November 02, 2014, 07:58:08 am »
im in the progess of trying to sort a group buy on these. anyone interested>?
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline paulw123
  • -Receive: 47
« Reply #12 on: November 03, 2014, 01:28:22 pm »
Offline DamoP
  • -Receive: 115
Offline paulw123
  • -Receive: 47
« Reply #14 on: November 03, 2014, 05:51:45 pm »
Reading through the other links, there seems quite a few problems with the AC etc working afterwards. It seems too complicated for me to attempt on my own, but if we all got together and had an expert on hand to help with the complicated stuff, I might be interested.
A kind of group buy/group fit  :signLOL:
