Author Topic: Rear anti roll bar  (Read 4613 times)
Offline chris-182
Rear anti roll bar
« on: April 14, 2014, 09:53:05 pm »
hi all, does anyone know where I can get hold of a standard rear anti roll bar from? anyone selling one on here? just spent £1400 on the car so not quite got the cash for a whiteline just yet and mine has snapped :(
Offline chris-182
Re: Rear anti roll bar
« Reply #1 on: April 15, 2014, 12:02:28 pm »
Can anyone shed any light for me?
Found a few second hand ones on ebay but are all for 2.0 TDI / 1.9 TDI / 2.0 SDI. Are these all the same or different fitments?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #2 on: April 15, 2014, 04:49:30 pm »
I think the fitment is the same, with exception of 4wd models, but the diameter and construction of the bar will vary between models.
Eg. Some are thicker than others, some are solid, some are hollow.
I have collected some info on this myself... I'll dig it out.
Jas
VCDS (Preston, Lancashire)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=q3g7uv1cakrhlemloq2qfui8ig&/topic,19740.0.html
« Reply #3 on: April 15, 2014, 04:51:55 pm »
Ive got one in the loft. Not practical to post it tho.
Offline chris-182
« Reply #4 on: April 15, 2014, 05:31:29 pm »
Jas
Cheers for that! if you could pass the info on I'd appreciate it :)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #5 on: April 20, 2014, 02:14:03 pm »
Ok, sourced from various google searches along with etka, here is the info I have so far.
I don't think the 4WD ARBs will fit a 2WD model, but I have one in the garage, im going to compare and see the difference soon.
Looks like the one to go for, if you can find it, is the Passat R36 ARB. Its a 23.6mm (same as GTI) but is a solid bar, rather than hollow.
Although the GTI version is probably easier to get hold of.
This table may not display properly in Tapatalk.
Front ARBs
CarDiameterWallPart No
Golf V GTi23.63.51K0 411 303 BK
Golf V TDI 1.922.53.51K0 411 303 Q
Golf V GT TDI 2.023.63.51K0 411 303 BK
Golf V R3222.0solid1K0 411 303 AQ
Golf VI GTi23.63.51K0 411 303 BK
Golf VI R22.0solid1K0 411 303 AQ
Passat R3623.6solid3C0 411 303 AA
Rear ARBs
Golf V GTi21.73.01K0 511 305 DF
Golf V TDI 1.9TBCTBCTBC
Golf V GT TDI 2.020.72.81K0 511 409 CA
Golf V R3221.73.01K0 511 409 BF
Golf VI GTi21.73.6TBC
Golf VI R21.73.6TBC
Passat R3621.73.63C0 511 409 E
Jas
« Reply #6 on: April 20, 2014, 02:18:23 pm »
Thought the gttdi was the same one
Offline biffobear
« Reply #7 on: April 20, 2014, 07:36:09 pm »
I have a standard rear gti roll bar lying around where you based
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #8 on: April 20, 2014, 07:36:40 pm »
PM'd
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline chris-182
« Reply #9 on: April 20, 2014, 11:50:59 pm »
cheers for the help guys! managed to sort one for £27 posted :)
Offline dan930
  • -Receive: 56
« Reply #10 on: April 21, 2014, 01:28:06 am »
I've also got a standard rear arb from an ed30...let me know if u want it,won't charge u for it,only p&p
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #11 on: April 21, 2014, 08:34:43 am »
Can anyone confirm the part no for the rear arb for gti?
Is it same as GT TDI 1K0 511 409 CA?
Offline chris-182
« Reply #12 on: April 21, 2014, 09:48:12 am »
that's very kind mate! if this one falls through I'll take you up on that :)
Offline dan930
  • -Receive: 56
« Reply #13 on: April 21, 2014, 12:20:05 pm »
No probs mate...where u located in the uk?
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline chris-182
« Reply #14 on: April 21, 2014, 04:32:09 pm »
in I'm Warrington mate, where are you?
