Author Topic: Possible Change needed in BSH Catch Can setup  (Read 14898 times)
Offline edition_30
Re: Possible Change needed in BSH Catch Can setup
« Reply #30 on: October 15, 2009, 04:24:10 pm »
Mine too.. have you fitted yet mate?
Offline edition_30
« Reply #31 on: October 16, 2009, 01:32:43 pm »
Any update on this guys as im fitting mine tomorrow & now not sure what way the hoses go
Offline KRL
  • -Receive: 29
« Reply #32 on: October 16, 2009, 01:46:50 pm »
Well annoyingly BSH are  not replying to emails  :fighting:
Has anybody asked Dubtek about this?
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #33 on: October 16, 2009, 02:08:24 pm »
what i did when dealing with bsh is wait till they open which in UK is quite late
i called them at about 6pm gmt and spoke to a bloke called justin..
he sounded like a hollywood actor lol YANKS!
he was helpful
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
« Reply #34 on: October 16, 2009, 02:21:17 pm »
You are not alone as the guys in the US seem to be constantly getting the same non-response as you when they email queries.
« Last Edit: October 16, 2009, 02:23:36 pm by bacillus »
Offline Janner_Sy
  • -Receive: 113
« Reply #35 on: October 16, 2009, 04:22:57 pm »
Mine was fitted by VWR and it was pointed out that where the pipes go into the head you can put your fingers in and make them touch so I don't see what difference it would make which way round the pipes were?  :confused:
afaik this reversal of hose routing is simply a preventative measure for when the can contents freezes in the harsh North American winters. The can should perform its job with either hose configuration.
IMO these points got to show that one of the pipes is acting as a breather to allow the flow of liquid, which otherwise would not flow unless pressurised.
Offline KRL
  • -Receive: 29
« Reply #36 on: October 16, 2009, 08:03:25 pm »
Managed to get a reply from Phil at last:
Hi Kristian, on the new can its best to run the right fitting to the side port. There are no ramifications of running it the opposite way, it just works better the other way.
-Phill
« Reply #37 on: October 16, 2009, 08:28:02 pm »
Well done, Kristian! :drinking:
I'm assuming that we've all got what Phil calls the 'new' can.
Offline KRL
  • -Receive: 29
« Reply #38 on: October 16, 2009, 08:29:16 pm »
Yes we have  :happy2:
« Reply #39 on: October 16, 2009, 11:03:49 pm »
Not all of us RR.   :wink:
Offline KRL
  • -Receive: 29
« Reply #40 on: October 17, 2009, 09:41:13 am »
^ I guess you did not get your catch can on the GB?
« Reply #41 on: October 17, 2009, 01:36:24 pm »
Correct.
« Reply #42 on: October 17, 2009, 01:44:27 pm »
Well, I now conclude that my 'wrongly' routed hoses are now 'correctly' routed without anyone changing them.
However, in spite of the tap being very tight it still spews oily gunk. I'm changing my catch tank anyway to one which has a sight feature. I'm sorry, I wish I could say otherwise but to be honest I'm not greatly impressed by BSH - Just my personal opinion :smiley:
Offline QD MBE
  • -Receive: 102
« Reply #43 on: October 17, 2009, 03:17:14 pm »
Robin,
The tap at the bottom - Have you wound it all the way in up against the base of the can?  If so it is wide open.  The tap needs to be fully out to be shut, Bear in mind it is a left hand thread too.
All the way to the bottom is correct, ie fully out.  I have had no probs with mine at all.
HTH
« Reply #44 on: October 17, 2009, 03:28:06 pm »
Robin,
HTH
....Aaaaaah! Duh, Robin, duh!!
Thanks Quality Dave! That would explain it. Nothing I could see in the BSH instructions about that :sad1:
Cheers, buddy! :drinking:
