Author Topic: Revo stage2+  (Read 5769 times)
Offline robern2
Revo stage2+
« on: October 23, 2009, 06:22:14 pm »
Apologies to those of you unfortunate enough to read my ramblings on other VW forums.
I've just returned from HLM in Bromsgrove following the fitment of revo stage2+ code and the ITG CAI to my edition 30.
I can genuinely say there is a night and day difference compared to stage 2 alone.
I thought the car was Car was quick before but the increase in both mid range and top end pull
is astonishing. Seemingly I'll run out of road before the car stops pulling.
I wasn't chasing 'dyno' figures though 358bhp/348lbs is a cracking result given the b7t5f6 settings which reflect
the car getting a little warm with it's standard intercooler after numerous runs.
The car remains just as easy to drive around at low speeds with no additional noise, it's only when pressing on
you experience a momentary fluttering sound from the CAI as it gulps in the new found air before taking off
like a scalded cat.
All credit to Revo and ITG for developing products that do exactly what they say on the tin which I believe is reflected in
very similar rolling road results with StevePs car. I wont steal his thunder, sufficed to say it's made me think about that
damn THS intercooler which did such a cracking job.
My thanks go to Hamish at HLM for the dyno time, Andy at ITG - a more clued up chap on induction technology you
will not meet, although that 96% oxygen compound stuff was beyond me :-)
Carl at revo for the stage2+ code, answering questions and tweaking my settings and SteveP, the first forum member
I've met in the flesh. (where do I get those vented honeycomb sections for the fog lights ?)
Nathan
« Last Edit: October 23, 2009, 06:23:49 pm by robern2 »
Re: Revo stage2+
« Reply #1 on: October 23, 2009, 07:26:25 pm »
Wow, great numbers...   :happy2:
Offline keith
Re: Revo stage2+
« Reply #2 on: October 23, 2009, 07:39:14 pm »
That some cracking figuers there Nathan what else have you modded on your Ed30, Its a BlueFlame TBE ?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Revo stage2+
« Reply #3 on: October 23, 2009, 07:58:09 pm »
Good to meet you today Nath  :happy2:
I will post my results shortly  :jumping:
Offline Janner_Sy
  • -Receive: 113
Re: Revo stage2+
« Reply #4 on: October 23, 2009, 08:24:49 pm »
is that the std airbox Vs ITG intake Dyno results steve :drool:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Revo stage2+
« Reply #5 on: October 23, 2009, 08:26:14 pm »
Oh yes and it's very very surprising  :surprised:
Offline Janner_Sy
  • -Receive: 113
Re: Revo stage2+
« Reply #6 on: October 23, 2009, 08:27:53 pm »
suprising good.....you cant leave ti like that come on :surprised:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: Revo stage2+
« Reply #7 on: October 23, 2009, 08:34:00 pm »
I will start my own thread shortly  :happy2:
Offline Janner_Sy
  • -Receive: 113
Re: Revo stage2+
« Reply #8 on: October 23, 2009, 08:35:13 pm »
aaahhhhhh the suspense :laugh:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Revo stage2+
« Reply #9 on: October 23, 2009, 10:54:22 pm »
great info but I need to ask a few questions...
1. graph of 2 runs is from revo stg2 to revo stg2+ ? can you give us the spec of your car for each run please?
2.stg2+ includes a HPFP yes?
3.why dont the power/torque curves cross at 5200 rpm ? (is that cos its in Nm?)
4. manual or DSG? (gearbox remap by any chance?)
5. is the wavey AFR the before or after ?
from the graph , it looks like +40 bhp across the rev range , I find that pretty hard to believe tbh but Im open minded.
he dip at 6500 for the stg2+ seems a bit odd too...
« Last Edit: October 23, 2009, 11:05:22 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline chungster
Re: Revo stage2+
« Reply #10 on: October 23, 2009, 11:25:12 pm »
i can believe an increase across the range as whole point of HPFP with S2+ file is to fatten the torque curve in mid range thru to top end...and that will increase ultimate bhp figs.
« Last Edit: October 23, 2009, 11:38:22 pm by chungster »
Offline Poppa Dom
Re: Revo stage2+
« Reply #11 on: October 23, 2009, 11:30:41 pm »
i can believe an increase across the range as whole point of HPFP is to fatten the torque curve in mid range thru to top end...and that will increase ultimate bhp figs.
Definitely agree with this Lee, this is what I found on mine.
Offline KRL
  • -Receive: 29
Re: Revo stage2+
« Reply #12 on: October 23, 2009, 11:38:46 pm »
Yes thats right and it makes sense when you think about.  The HPFP is cam driven so it is going to struggle most at lower revs when boost is coming on strong (3-4k rpm).  At this point the ECU will be asking it for a lot of fuel pressure to meet the required AFR with the extra boost kicking in.  This is when the standard HPFP is at its most vulnerable because it has to work harder to supply the required pressure as the cam is not driving it as hard with lower revs.
An upgraded HPFP is able to meet higher fuel pressure requirements at lower revs.  Hence the best gains with a HPFP are seen through the mid range and headline figures will not be that different.
Offline robern2
Re: Revo stage2+
« Reply #13 on: October 24, 2009, 07:39:28 am »
Keith, the car is indeed running blueflame turbo back along with an autotech pump and forge dv, it's also manual.
The runs against my car were using the same hardware in all cases the only difference was going from stage 1 software with default settings to stage2+.
The 40bhp increase across the range surprised HLM also. As Steve had more combinations of runs, I'm sure his graphs will demonstrate the point more easily.
Popping out to my local tuner to show him how it looks and goes now :-)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: Revo stage2+
« Reply #14 on: October 24, 2009, 10:00:01 am »
looking good, get the settings back up one on the boost b8 and your laughing.
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
