Author Topic: Windscreen wipers ONLY start at 10MPH  (Read 2111 times)
panther33
« on: January 06, 2015, 12:04:42 pm »
Has anyone had the same problem? Cannot get MOT as the wipers need to work when car is stationery ... any ideas? Many thanks
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Windscreen wipers ONLY start at 10MPH
« Reply #1 on: January 06, 2015, 12:06:10 pm »
Motor on the way out? Can you scan it?
Offline xjay1337
  • -Receive: 377
« Reply #2 on: January 06, 2015, 12:15:50 pm »
they work in Auto when you go over 10mph from stationary same as when the doors lock
they will still work when you manually flick them (down) or put them on full (normal or maximum speed)
switch goes
full - fast
full - normal
auto
off
manual one flick
easy really
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #3 on: January 06, 2015, 12:57:09 pm »
Mine were doing this when the bonnet catch was playing up.
The car thinks the bonnet is open and so doesn't let the wiper work when stationary, regardless of position of the stalk.
Although if this is the case, you should have a bonnet open warning on dash?
Jas
VCDS (Preston, Lancashire)
Offline Wash
« Reply #4 on: January 06, 2015, 05:06:49 pm »
Yeah, this happens when the car thinks your bonnet is open. You sure your bonnet switch works?
« Reply #5 on: January 06, 2015, 05:48:14 pm »
Happened to me when the bonnet wasn't closed properly
