Author Topic: arm rest 6 disc CD changer issue  (Read 4801 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: January 11, 2015, 11:00:41 pm »
CD changer under the arm rest doesn't work as there seems to be no lights on it and when pressing the buttons no noises  :surprised:
Does it have a fuse?.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: arm rest 6 disc CD changer issue
« Reply #1 on: January 20, 2015, 07:44:18 pm »
Wow no one  :surprised: the tt forum is spot on for help or would have answered this ages ago. Shame
« Last Edit: January 20, 2015, 08:32:23 pm by r5gtt »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: January 21, 2015, 11:42:08 am »
The forum is actually very helpful, there's a good chance your question was asked at a busy time so it just got pushed back to the end of the queue!
In 2 years of very active use of this forum I've never seen that issue arise.
I have a 6 disc changer also and have not had this problem.
Check your handbook for the fuse layout and start with that, next up would be to remove the changer and examine it. Is this just a recent occurrence or was it like it since you got it? Maybe water was spilled inside it? Good luck! Maybe someone else can shed some light
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: January 21, 2015, 11:05:51 pm »
Hi luke, thanks for your reply.
Your probably right with the responses but guessing the audi tt forum is a little different from the gti one.
I'll try the fuse and see what other things I can do eh take the unit out and check for power etc
Thanks again
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: January 22, 2015, 08:17:14 am »
Let us know how you get on if you solve the problem for people searching this thread down the line and also don't be afraid to bump the post now and then to get it to the top of the list again.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #5 on: January 22, 2015, 09:46:16 am »
the cd changer used to suffer with the cd getting stuck inside. but if you have no power a fuse would be a good start. has it work anytime you have owned the car?
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: January 22, 2015, 07:12:47 pm »
Hi DamoP I've recently bought the gti and it never worked from the day i found it as silly me didn't check to see if it had one :ashamed:
I've not had time to check yet but will do hopefully soon.
thanks
Offline DamoP
  • -Receive: 115
« Reply #7 on: January 22, 2015, 07:33:06 pm »
thanks
this will sound like a stupid question. but might be worth taking it out to see if it has the wiring. lots of people retro fit the armrests and some come with cd changer. let me know if you need any tips on removal
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: January 22, 2015, 08:19:31 pm »
OMGOSH really?. Not stupid at all mate, it is a possibilty lol
I've got to check it out ASAP  :surprised:
Thanks a lot for that. I'll let you know what happens.
How easy is it to remove please.
Offline DamoP
  • -Receive: 115
« Reply #9 on: January 22, 2015, 08:37:41 pm »
armrest are on of the first things lots of people do. and unless you check the cable wouldnt be there if it ws retro fitted.
ive got an how to fit an armrest ill post for you, follow this to the stage of taking the armrest casing off. if you need a cd changer loom i have a few at the mo
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: January 22, 2015, 08:42:06 pm »
Ah that's brilliant wow things are looking up now  :drinking:
Offline DamoP
  • -Receive: 115
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: January 22, 2015, 09:03:43 pm »
That's looks like a mission and a half  :scared:  :signLOL: I'll give it a go this weekend thanks ever so much Damo  :wink:
Offline DamoP
  • -Receive: 115
« Reply #13 on: January 22, 2015, 09:06:13 pm »
its acutally a 2 mins but if you know where the screws are and have the correct bit
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: January 22, 2015, 09:41:38 pm »
I'll check the pics for the screws as I have torx bits spanners and screw drivers to hand. It's like replacing the wishbone bushes on the tt were like over two hours the first time and half an hour the second time 3 years later lol
Basically once you know you know  :laugh:
« Last Edit: January 22, 2015, 09:57:47 pm by r5gtt »
