Author Topic: Mk6 gti clocks with white display onto mk5?  (Read 11970 times)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Mk6 gti clocks with white display onto mk5?
« Reply #15 on: February 02, 2015, 09:50:39 pm »
to make it simple, which pumps are ok with white cluster
Any other variations I will add to the list
Doesn't Work:
1K0 907 379 P (non ESP Caddy)
1K0 907 379 K
Works ok:
1K0 907 379 Q
1K0 907 379 AA
1K0 907 379 AC
1K0 907 379 AF (non ESP Caddy)
Cluster and Key coding
Location Great Yarmouth
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #16 on: February 02, 2015, 10:48:45 pm »
@olsen-72 did you have any ABS fault codes after you changed these clocks? Any chance you saved a scan of his car to see the ABS part number?
No faults at all. Straight swap. Can't remember PN from top of my head and I'm not by my laptop atm.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Matto
  • -Receive: 116
« Reply #17 on: February 02, 2015, 11:03:59 pm »
Let me know if you need a set of MK6 highline clocks  :happy2:
Offline jedi-knight83
  • -Receive: 41
« Reply #18 on: February 04, 2015, 10:05:00 pm »
Is it possible to get the same hill hold capability as my 2012 caddy if I upgrade the abs pump? Was reading that's how that feature was controlled.
Also is it easy to change to the mk6 climate. I'm thinking if I update the clocks the only blue background light would be the mk5 climate and that would look odd.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #19 on: February 04, 2015, 10:08:55 pm »
Climatronic can be upgraded
Panel + new surround + swap few wires on the back.
Offline GTi-Andy
« Reply #20 on: February 04, 2015, 10:21:19 pm »
Yup I've got that too ^^^ easy mod that lifts the interior to a more modern look
So much for keeping it standard!
solar_sky
« Reply #21 on: June 20, 2016, 08:39:15 am »
Doesn't Work:
1K0 907 379 K
Works ok:
1K0 907 379 Q
1K0 907 379 AA
1K0 907 379 AC
Hi Eddie, i happen to have 1K0 907 379 Q. Will it work with colour or 3d colour cluster?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #22 on: July 04, 2016, 09:38:42 am »
Yes it will work
Offline AlexAlmostDSG
« Reply #23 on: September 15, 2016, 02:27:10 pm »
Hello Eddie - where can i get in touch with you regarding this retrofit, please?
Regards
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #24 on: September 17, 2016, 07:32:22 pm »
Regards
send me a message on ebay
http://www.ebay.co.uk/itm/131936628655?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
byukow
« Reply #25 on: November 12, 2016, 08:28:12 am »
Doesn't Work:
1K0 907 379 K
Works ok:
1K0 907 379 Q
1K0 907 379 AA
1K0 907 379 AC
I have VW golf5 (year 2005) and old ABS pump (1K0 907 379 P). I tried with white cluster VW Scirrocco (golf6 plus) and changing the ABS pump (1K0 907 379 AQ). So in theory it should work but when my 'mechanic' tried to code new ABS to the car it doesn't accept the code. Is there any special thing that should be carefull when coding the new ABS pump? The cluster worked fine just there was error with ABS (in VCDS) so swaped back to normal (old - half red cluster cluster and old ABS pump) so now I am at the begining of project.
Would you be so kind and give me some advice about coding? I am from Slovenia. :)
Is it supposed to be normal coding or is there any catch?
« Last Edit: November 12, 2016, 02:31:27 pm by byukow »
« Reply #26 on: November 16, 2016, 02:00:27 pm »
Regards
Done, message sent, hoping to get in touch :)
