Author Topic: pirelli misfire issue  (Read 11688 times)
Offline noszex
« on: November 27, 2009, 07:12:34 am »
hi,
my pirelli seem to misfire always on s mode only. i have read quite a few thread and would like to how do i solve this problem.
is the valve spring that is wrong for the vehicle or the tuning map not suitable?
anyone can advise?
Offline tony_danza
  • -Receive: 112
Re: pirelli misfire issue
« Reply #1 on: November 27, 2009, 09:57:50 am »
Firstly - scan it with VAGCOM and see what the fault log says, otherwise you'll end up chasing your tail.
It could be anything, I'd put my money on a coilpack being on its way out.
Sideways yo!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: November 27, 2009, 11:16:12 am »
Like Tony D says without the scan your pissing in the wind.
Also be helpful to know the what hardware mods and software your running.  :happy2:
Offline Rich
    • Carpet Underlay
« Reply #3 on: November 27, 2009, 11:18:53 am »
Are you having misfires when your floor it ???
i.e over 5,000 revs ?
I've had no problems with my Pirelli remap from REVO for 2 months now...
I think Carl at REVO HQ had to mess around with it at first, but its silky smooth and perfect now happy2
I know the Pirelli map is different to the ED30 remap... so im guessing this what it might be...
If i was you, id get it remap at REVO HQ with Carl
Offline noszex
« Reply #4 on: November 27, 2009, 03:45:00 pm »
vagcom  say misfire cylinder 3. had this always on 3, car is 2mth old 4200km.
coilpack swop and plug change new still same issue. it should not be coilpack or plug issue, i had a friend who is in giac tune with same issue misfire at WOT trottle high RPM.
so i wonder if its the tuning that is the problem, stock nv had misfire before.
i did read on some thread saying the valve spring is wrong ?
Offline KRL
  • -Receive: 29
« Reply #5 on: November 27, 2009, 04:25:09 pm »
Takes some logs with VCDS of these engine blocks as a starting point:
Misfire-Specific DIAGNOSIS
Item #   Vag-Com Block #   Description
1   001-1   Engine Speed
2   054-3   Accelerator Pedal Position
3   054-4   Throttle Plate Angle
4   101-3   Injection Timing (Median)
5   115-3   Boost Pressure (Specified)
6   115-4   Boost Pressure (Actual)
7   003-2   Intake Air Mass
8   230-2   Rail Pressure - Actual
9   015-1   Misfire Cyl 1
10   015-2   Misfire Cyl 2
11   015-3   Misfire Cyl 3
12   016-1   Misfire Cyl 4
Offline noszex
« Reply #6 on: November 27, 2009, 04:28:53 pm »
done the data log with the misfire flashing with the giac dealer, waiting for the usa giac to respond.
so isit the map issue or there is something wrong with 08 car?
Offline berttie21
« Reply #7 on: November 27, 2009, 04:48:28 pm »
Hi there,
My Pirelli 58 plate did the same with a Revo S1, It was recored as a misfire but i don't actually think it did, just cam near it so the sensor used to throw the light on.
I had my code renewed with the latest Revo Pirelli edition software (apparently they have a sightly different rail to the Ed30 engines) and the problem has totally gone.
Mine only used to misbehave at the redline?
Offline Rich
    • Carpet Underlay
« Reply #8 on: November 27, 2009, 05:41:15 pm »
Hi there,
Nos i guarentee you its the software 100%
Before i bought my pirelli 58 plate, i managed to speak with the previous owner... he said he had REVO remap and it was misfiring all the time when he floored it.. so he took it off...
BUT - REVO have solved this problem, they've bought out a REVO Pirelli remap ( which i got at HQ Revo in Northamtonshire by Carl ) which solves ALL the misfire issues.
I'm 100% positive this is your problem :happy2:
Offline candy turbo
« Reply #9 on: November 27, 2009, 05:52:26 pm »
i ve never read a bad word on here about CUSTOM CODE  (just my 2 p worth )
« Reply #10 on: November 27, 2009, 07:10:31 pm »
Thanks for that KRL :happy2:
I'd been wondering about the misfire blocks
« Reply #11 on: November 27, 2009, 07:12:58 pm »
I used to have Custom-Code software on mine.
I still rate it, but it just didn't give me the aggressiveness that I was after, or the flexibility that the REVO SPS+ controller gives.
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #12 on: November 27, 2009, 09:01:22 pm »
nosex, revo borrowed my pirelli for a week to log and tweak the map, it was constantly misfiring at 6,500rpm, its now done 6,000 miles mapped and no issues
the misfire has also affected some Leon's and S3s
my car is going back into revo after its first service (which is due soon) to try the original map soon
it would appear you can't assume a Ed30 map runs on a Pirelli
« Reply #13 on: November 27, 2009, 09:16:03 pm »
To the OP what fuel are you using?
Cylinder 3 is the normal weakspot as it is either the longest or shortest intake path.
Offline noszex
« Reply #14 on: November 28, 2009, 12:36:05 am »
i have heard APR tuning map to suit pirelli to so that misfire has disappear . still waitin for the GIAC.
using caltex 98. i am not from UK.
for revo stage 1, no hardware needed
stage2 TBE + intake
stage2+ HPFP
is the above correct?
