Author Topic: Timing Chain kit  (Read 8197 times)
Offline Pesky jones
Timing Chain kit
« on: July 08, 2015, 12:51:56 pm »
So at some point I'm going to have to replace the timing chain due to the diesel noise and me being paranoid about it slipping etc.
I'm going to get a garage to do the replacement for me, as I don't think i'll be able to. I've also emailed Volkswagen to get a price on the chain, tensioner and bolt, and also how much for them to fit it.
If it is considerably more expensive to get it genuine from Volkswagen, ill use one of the following kits and get an indpedent specialist to fit the hit.
http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Engine/Timing/ES2765389/
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2005/p/car-parts/engine-parts/belts-chains-and-tensioners/timing-chain/?352440181&1&e6e3cd0b3da2b86e4b2f1bfdd88d1a0bab25d494&000582
Any comments guys?
Offline Dubdanr32
Re: Timing Chain kit
« Reply #1 on: July 08, 2015, 06:09:46 pm »
I'm just in the process of getting mine replaced by my pal who has his own vw specialist garage, so I will let you know how much it costs. All parts are from volkswagen and I think the chain was £40 tensioner is about £90 bolts a couple of quid plus labour. Mine was sounding terrible, like a tractor with no engine oil bad!
Offline Pesky jones
« Reply #2 on: July 09, 2015, 12:17:26 am »
Brilliant that would be great if you could let me know. I've heard that if you get the adjuster done as well, then with labour you won't get much change from a grand! The adjuster is ridiculously expensive however. I don't think il get the adjuster done.
Offline Gmaster
« Reply #3 on: July 09, 2015, 10:30:32 am »
Yep the adjustor is expensive, but many people have not changed it and still had the diesel sound.
I'm gonna get mine changed for peace of mind.
Offline Pesky jones
« Reply #4 on: July 09, 2015, 10:50:21 am »
I've also read a few posts where people haven't changed it and its been fine. I havn't actually seen or met anyone that hasn't changed it and still had the noise.
If I get it all changed, and it still makes the noise, then i'll have to cough up for the adjuster and extra labour, but at least the cost will be spread out. Fingers cross I don't even need to!
Offline neiller
  • -Given: 32
« Reply #5 on: July 09, 2015, 01:34:55 pm »
I was on the phone with my local vw dealer this morning to get a price for cam chain ,tensioner and fuel pump cam follower think it was £60 £100 £30 that's including vat ! I have the dreaded rattle.after engine is warm so I expect to have to change these parts next Monday at service hopefully the labour cost isn't too much
Sent from my SM-N9005 using Tapatalk
Offline Pesky jones
« Reply #6 on: July 09, 2015, 01:54:44 pm »
Hmm well it could be done for under £300 then... Sounds good i'm going to do it next month I reckon.
Offline dom069
« Reply #7 on: July 09, 2015, 02:05:19 pm »
I'd get the valve cover gasket as well.
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline neiller
  • -Given: 32
« Reply #8 on: July 09, 2015, 02:23:34 pm »
I was told that it's a rubber gasket and could be reused but was going to order another one anyway any idea of that price if the gasket ?
Offline dom069
« Reply #9 on: July 09, 2015, 05:12:03 pm »
Personally I'd never reuse one, at a guess I'd say about £15.
Offline Gmaster
« Reply #10 on: July 09, 2015, 07:44:43 pm »
Well if that is the case then that's good to know, might be able to save myself some money, have to wait and see.
Offline Pesky jones
« Reply #11 on: July 10, 2015, 12:23:56 pm »
Well I got a scary email today from VW:
To replace the Cam chain the Prices are as follows :
Chain Pic 2 Item 3         : 06D109229B   £66.50 inc vat
Tensioner Pic 2 Item 4   : 06F109217A   £101.14 inc vat
Bolt Pic 2 Item 7            : 06D109281D  £3.42 inc vat
Sealant Pic 1 Item 10     : D154 103A1   £68.94 inc vat
Parts Total                                               £240.00
If Item 6 In picture 2 The Camshaft adjuster is required it only comes with Item 15A Picture 1
Camshaft Adjuster Pic 1 Item 15A  06F198088D £438.40 inc vat
Parts Total Including Item 6  : £678.40
The labour to replace the cam chain is quoted at 2.5 Hours so £345.00 including vat
I’m thinking that I’ll get the chain and tensioner for £166  from VW and take them to an independent VW specialist, and see what labour cost they’ll give me.
Hopefully around 250, so all in all around 400
Offline dom069
« Reply #12 on: July 10, 2015, 12:26:00 pm »
They charge almost £140 an hour labour?!!
Offline Pesky jones
« Reply #13 on: July 10, 2015, 12:54:53 pm »
Apparently so. Is this not a fixed price everywhere?
Offline dom069
« Reply #14 on: July 10, 2015, 12:59:32 pm »
I've no idea, I avoid main dealers if I can help it. I knew that they charged a lot but had no idea it was that much!
