Author Topic: Ram Air Induction Kit  (Read 39106 times)
Offline irish_ram
  • -Given: 200
Re: Ram Air Induction Kit
« Reply #30 on: August 19, 2015, 12:23:18 pm »
Don't have a clue but got mine delivered today so if you let me know I can check mine is okay before I start fitting it tonight  :surprised:
Offline irish_ram
  • -Given: 200
« Reply #31 on: August 19, 2015, 03:56:06 pm »
well seems ive ordered the intake kit from hell.   :laugh:
any one have a guess what the problem is ?
See it now I think ,have they sent you the same part twice as checked mine and all the right parts
Offline th3_f15t
  • -Receive: 183
« Reply #32 on: August 19, 2015, 04:07:00 pm »
Bit of shameless advertising here, but I'm after a stock engine cover and air feed, willing to pay cash or swap for my RamAir kit like-for-like. I have a K03 system if that helps. Anyone who has a stock engine cover and wants a few quid for it, give me a shout and we'll strike a deal.
Offline dronners
« Reply #33 on: August 19, 2015, 04:42:12 pm »
Correcto theyre quite promptly sorting it out which is good but now have half an intake fitted
Offline irish_ram
  • -Given: 200
« Reply #34 on: August 19, 2015, 08:27:39 pm »
So fitted mine and some pics below and also took it for a spin and louder than I thought but nice sound when accelerating.
On the downside I did manage to break the piece of plastic pipe that comes off the Turbo Inlet so good thing I fitted the new one ok as no going back  :confused:
The pipe with the MAF on wiggles a bit even after fixing and tightening the claps so hope that is normal
Few pics
Offline jp700
« Reply #35 on: August 22, 2015, 03:53:10 pm »
Thinking about getting one of these. Are you guys running them with standard ECU settings or have you had a remap? I have a standard GTi (197bhp) with KO3 turbo - does this mean I get the 70mm Ramair kit or can I run the 90mm version? Also, does the cone filter just rest on the inside of the heat shield or is it bolted to something to stop it moving about?
Sorry for all the questions! Thanks in advance.
JP.
Offline irish_ram
  • -Given: 200
« Reply #36 on: August 22, 2015, 06:05:41 pm »
JP.
I cannot be 100% sure but from doing a couple of VCDS runs my car looks like it has had a Stage 1 map before I bought it. I have the 70mm version on my ED30 so not sure on that. My filter doesn't rest on anything and I did this by adjusting the 90 degree silicone hose before clamping on, it does move around but I made sure there is clearance all around so it does sit on anything but is very tight in there
Offline dronners
« Reply #37 on: August 22, 2015, 08:01:26 pm »
same as above really just gotta adjust so its just barely floating  mines running on standard ecu just fine
Offline irish_ram
  • -Given: 200
« Reply #38 on: August 22, 2015, 09:02:10 pm »
Just figured out where the RamAir sticker is supposed to go  :happy2:
Offline jp700
« Reply #39 on: August 25, 2015, 05:34:33 pm »
Thanks for the information guys - good pic dronners, looks nice and clean under your bonnet. I'm gonna definately think about this as long I don't lose any horseys by fitting it.
Offline Jay_ed30
« Reply #40 on: August 25, 2015, 09:23:19 pm »
I have the 90mm oversize kit fitted to mine the heatshield is a bit tricky over the manifold but other than that it's straight forward. It's sounds good and also feels abit more responsive on my ed30
Offline Jay_ed30
« Reply #41 on: August 25, 2015, 09:24:33 pm »
Second pic is before cleaning the bay
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #42 on: August 25, 2015, 09:27:28 pm »
I also have one of these great value kits - been on a couple of months now and works a treat
Wrapped mine in magmashield heat reflective tape for a bit of engine bling!
Offline Dave(tm)
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89462.0.html
« Reply #43 on: August 25, 2015, 09:27:52 pm »
I'd love to do a swap, but you're probably a little far from me unfortunately.
Dave
Offline irish_ram
  • -Given: 200
« Reply #44 on: August 25, 2015, 09:32:03 pm »
As you can see from my pic I need to clean my engine bay badly. what did you use to clean yours especially around the battery and fuse kit as if I use water spray am worried about getting it into these
