Author Topic: Intermittent rear wiper fault  (Read 14708 times)
Offline GTIEagles
« on: August 25, 2015, 12:59:15 pm »
My car had it's MOT last Friday and passed with no advisorys  :happy2: but over the last couple of days the rear wiper has refused to work. I can hear the relay click when activated but no movement. Although it worked again briefly yesterday but stopped working when I used the car later that day...
Any ideas?
Offline perksy
Re: Intermittent rear wiper fault
« Reply #1 on: August 31, 2015, 12:24:56 pm »
I've got the same problem in reverse.
Sometimes when I start the car the rear wiper starts and won't stop until I start the car and restart again.
Any ideas?
James
Offline hlcst
« Reply #2 on: August 31, 2015, 01:30:47 pm »
Have you checked the fuse bud? I removed my fuse when I decided to de wiper and it still clicks when I put it in reverse
Offline white91
« Reply #3 on: August 31, 2015, 07:58:03 pm »
Any ideas?
James
I get this too
Offline PM30S
  • Edition 30 Revo Stage 2+
« Reply #4 on: August 31, 2015, 08:50:05 pm »
My edition 30 had the rear wiper removed when purchased.
I cannot get the rear wiper to work on its own.
The only way it will work is if I spray the front screen with washer fluid, then it wipes the rear screen 4 or 5 times.
Very strange.
Offline GTIEagles
« Reply #5 on: September 01, 2015, 08:11:53 pm »
Well since the weekend, mine seems to be working again, very strange I guess it's probably a loose connection somewhere?
Offline Ricky123
  • -Receive: 27
« Reply #6 on: September 03, 2015, 01:06:30 am »
Audi a3's of similar year to mk5's suffer from water off the rear washer leaking into motor and cause them to act like there possessed lol
Could be that?
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline missymckay
« Reply #7 on: September 03, 2015, 10:20:17 am »
I had a similar issue with mine. It turned out to be issues with the wiring loom in the bit that goes from the car to the tailgate. I had to have the wires put back together as they were falling apart. Since the repair, it works fine :)
AmD stage 1
Offline GTIEagles
« Reply #8 on: September 03, 2015, 10:45:57 am »
Could be that?
Do you know of a fix?
Offline GTIEagles
« Reply #9 on: September 03, 2015, 10:47:00 am »
Thanks I will check it out, I will also put it on VCDS and see if any errors come up.
Offline Ricky123
  • -Receive: 27
« Reply #10 on: September 03, 2015, 04:06:31 pm »
Could be that?
Replacing the wiper motor was the cure when I had mine as the motor and washer pump are a combined unit
59 red mk6 GTi 5dr
Offline GTIEagles
« Reply #11 on: October 06, 2015, 10:38:35 am »
Update to this post:
I have found that by squeezing the wiring that goes from the roof of the car to the boot, I can get the wiper working again. So I guess that means there must be a fault with the wiring somewhere? Is there any easy way to check?
Offline GTIEagles
« Reply #12 on: October 06, 2015, 11:11:56 am »
Done some digging around and found this very helpful guide: http://www.mk5golfgti.co.uk/forum/index.php?topic=86689.0
I'm hoping mine is not as serious but at least I know there is a solution!
Offline SiofChester
« Reply #13 on: October 07, 2015, 01:33:40 pm »
I went through a bunch of debuigging on this, wiring checks etc etc Turns out it was the motor. BOSCH motor off the bay of e and its been reliable for 6 months now
Offline GTIEagles
« Reply #14 on: October 07, 2015, 03:06:56 pm »
It definately is the loom, I checked it last night and found this:
It's probably the reason why the high level brake light is dead too!
