Author Topic: Ed30 problem  (Read 1332 times)
Offline S800BRN
  • -Receive: 27
Ed30 problem
« on: September 02, 2015, 09:50:30 am »
Mornin all!
So at the weekend my oil pressure warning flashed on then disappeared only for it to come on again with 20 minutes or so. I pulled in and opened my bonnet. Found oil in bay - over the cambelt cover and had obviously dripped down the exhaust and had sprayed over my boot.
I turned the car over and saw the revs increase without touching the throttle. I then shut it off and had it recovered.
I thought maybe PCV (the revs rising) or maybe blocked oil pick up. Neither really explain the leak though.
It's a 57 plate manual Edition 30. 79k miles.
Full service history.
Any ideas?
« Last Edit: September 02, 2015, 10:00:59 am by S800BRN »
Offline Jay_ed30
Re: Ed30 problem
« Reply #1 on: September 02, 2015, 01:18:23 pm »
It could be your pcv as I'm sure one of the symptoms of a failed pcv is pushing oil out of the filler cap.
Offline Trow81
Re: Ed30 problem
« Reply #2 on: September 03, 2015, 02:08:21 pm »
As above sounds like pcv I would start there
