Author Topic: request for info : OEM 312mm (GTI) setup VS OEM 345mm (R32 S3) weights  (Read 15187 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
ok , cant find it all in internet so Im sure one of you knowledgeable lot will know
I want to know how much difference in kg there is between the OE GTi setup and R32/S3 345mm setup.
I know its a lot of kg ( :surprised:) but want the numbers....
all good stuff to be added to a product review :wink:
thanks
John
so far I have
from here
http://vorsicht.org.hk/forums/showthread.php?t=3076
GTI
Brake Disc Diameter, mm : 312 (F), 286 (R)
Brake Disc Thickness, mm : 25 (F), 12 (R)
Caliper Piston Diameter, mm : single, 54 (F), single, 38 (R)
R32
Brake Disc Diameter, mm : 345 (F), 310 (R)
Brake Disc Thickness, mm : 30 (F), 22 (R)
Caliper Piston Diameter, mm : single, 57 (F), single, 41 (R)
and dunno if correct but  for FRONTS
OEM Rotors 312mm (7.75 kg)
OEM Caliper & Carrier (5.5kg)
OEM Rotors 345mm (12kg)
OEM Caliper & carrier ( 9kg)
RR posted this about the REARS
Weight R32 Rotors, Calipers, Carriers & bolts (without pads) = 22.4 lbs / 10.2 kg
Weight OEM Rotors, Calipers, Carriers & bolts (without pads) = 17 lbs / 7.7 kg
« Last Edit: December 22, 2009, 02:40:26 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: request fro info : OEM 312mm (GTI) setup VS OEM 345mm (R32 S3) weights
« Reply #1 on: December 21, 2009, 10:36:06 am »
i'll try and weigh mine later  :happy2:
disc 312mm 7,75kg
caliper and carrier 5,5kg
 :pomppomp:
« Last Edit: December 21, 2009, 04:58:23 pm by danishmkvgti »
Over the top mod list ;o)
Offline Janner_Sy
  • -Receive: 113
Re: request for info : OEM 312mm (GTI) setup VS OEM 345mm (R32 S3) weights
« Reply #2 on: December 22, 2009, 02:37:52 pm »
what could also be handy is if you could get the weight of the standard control arms and the cupra/S3 aluminium control arms as they are used to offset the additon in weight of the heavier R32 brakes.
im ot help there. when i sold my full R32 fronts including everything other than carriers, it came to about 43kg for postage iirc
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: December 22, 2009, 02:41:35 pm »
cheers guys  :happy2:
looks like approx 7.5kg per side (front) for going up to R32 which is HUGE !
Red ED35 5dr DSG
BLOG | BUILD
« Reply #4 on: December 22, 2009, 02:53:17 pm »
Re GTI oem FRONTS: Whole assembly of disc plus calipers = 15.10 Kg each. (10.6 Kg for AP Racing's kit).
I've never weighed any rears.
HTH  :happy2:
  • -Given: 243
  • -Receive: 155
« Reply #5 on: December 22, 2009, 05:14:34 pm »
Someone here linked to an audi forum where the weight difference were mentioned, i have it somewhere.
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: December 22, 2009, 05:27:32 pm »
found it,
the weights for lower control arms are...
GTI/Ed30 = 4100 grams each
S3 /cupra= 2290 grams each
would presume the TT lower arms are neigh on exactly the same
  • -Given: 243
  • -Receive: 155
« Reply #7 on: December 22, 2009, 07:44:59 pm »
found it,
 :happy2:  :santa:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #8 on: December 22, 2009, 09:52:18 pm »
HTH  :happy2:
thanks RR but Im not sure now??
danishmkvgti has just quoted
disc 312mm 7,75kg
= 13.25kg total
youve said 15kg , does that include the CV joint and hub then??
little confused
Red ED35 5dr DSG
BLOG | BUILD
  • -Given: 243
  • -Receive: 155
« Reply #9 on: December 22, 2009, 10:17:57 pm »
HTH  :happy2:
disc 312mm 7,75kg
= 13.25kg total
little confused
I'm confused to, but my dad watched me weigh the parts, i'll ask him tomorrow if i forgot the carrier weighing the caliper
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Compare RS3/TT-RS brakes to the S3 ones:
OEM:
stock 312mm - 14.5kg
TT-S 340mm - 20kg
S3/R32 345mm - 21.5kg
TT-RS 370mm - 17kg
RS4/RS6 365mm - 17kg
RS6 V10 390mm - 21.5kg
Non OEM:
VW-R 352x32mm - 12kg
K-Sport 356x32mm - 12.25kg
Brembo 355x32mm - 13kg
(caliper + rotor + pads + bolts + adapter)
"You get what you pay for."
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
OEM:
stock 312mm - 14.5 kg
TT-S 340mm - 20 kg
S3/R32 345mm - 21.5 kg
TT-RS 370mm - 17 kg
RS4/RS6 365mm - 17 kg
RS6 V10 390mm - 21.5 kg
Non OEM:
AP Racing          - 10.6 kg
VW-R 352x32mm - 12 kg
K-Sport 356x32mm - 12.25 kg
Brembo 355x32mm - 13 kg
Jake, what size are the AP?
AP Racing GTI: 10.6 kg - 330 x 28 mm
OEM GTI: 15.6 kg
Both measured on same scales at AP Racing in same session and witnessed by myself.
« Last Edit: June 05, 2011, 04:27:42 pm by RedRobin »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
OEM:
GTI 312mm - 15.6 kg
TT-S 340mm - 20 kg
TT-RS 370mm - 17 kg
Non OEM:
AP Racing 330x28mm - 10.6 kg
The 14.5 kg were from a TT-S form. Maybe the TT rotors weigh less . . .
Offline Kesh
« Reply #14 on: August 02, 2018, 12:27:44 pm »
I know this thread is old now..... but im going  upgrade brakes on my ed30.... going for audi s3 8v 2017 calipers with mk7 gti clubsport s 340mm x 30mm discs to save a bit of weight.... anyone run this set up.
Also what pads would one recommend for this application for fast road driving...and maybe a bit of tracking?
 Cheers.
BLK, 3dr, 6spd, Ed30. Stage 2, Scorpion TBE, KW v2, revo intake, Powerflex, GFB DV+, Need Better Brakes....HELP!!!
