April 08, 2025, 06:56:29 am
All Things Mk5
Performance Modifications
Porsche Panamera calipers adapters for mk5
Topic: Porsche Panamera calipers adapters for mk5 (Read 4074 times)
killer666
September 07, 2015, 03:33:13 pm »
I want to mount the Panamera 6pot calipers on my mk5, but I can't seem to find adapters for them, I will be using them with the ML 350mm discs
Did you guys try this on your cars?
Shoduchi
Just look at my post count
-Given: 220
-Receive: 429
My Ride:
Re: Porsche Panamera calipers adapters for mk5
Reply #1 on:
September 10, 2015, 05:07:33 pm »
Wouldn't it be easier and cheaper to get Porsche Cayenne's 6 pot calipers? There are lots of sellers for the adaptor bolts...
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
killer666
Reply #2 on:
September 10, 2015, 05:13:24 pm »
No:) because I already have the panamera calipers:)
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #3 on:
September 10, 2015, 05:18:57 pm »
I'm not sure there is any yet, but contact someone like Vagbremtechnic to see if they can help you out.
https://www.facebook.com/vagbremtechnic
Also worth seeing if the ML350 discs will work wih those calipers, as mentioned they work for the Cayenne 6 piston calipers so may also work. Saying that, if the calipers you have are only slightly different in shape, may offer them up to the hub and see, as when fitting Cayenne calipers to a mk5/6 hub you just need the adapter bolts, no brackets...
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #4 on:
September 10, 2015, 05:27:25 pm »
Some further Google searches showed this:
https://www.google.co.uk/search?q=vw+golf+cayenne+brakes&biw=1600&bih=775&source=lnms&tbm=isch&sa=X&ved=0CAYQ_AUoAWoVChMItJaQgvDsxwIVJpvbCh0XVwi_#imgrc=_
Now I searched for 'Cayenne' calipers but clearly some of the images are of the same calipers you have, so I'd imagine it's a similar build to the Cayenne 6 pistons. All you'll need then is bolts and lines:
Bolts -
http://www.ebay.co.uk/itm/Vw-Golf-Mk5-Mk6-Mounting-Bolts-for-Porsche-Cayenne-Calipers-Audi-Q7-Brembo-/111067552499?hash=item19dc245af3
Lines -
http://www.ebay.co.uk/itm/VW-Golf-Mk6-R-GTI-TDI-to-Porsche-Caliper-Conversion-Front-HEL-Brake-Lines-/231480180702?hash=item35e54b3fde
I can't say for certain these will work, but it's my best guess...
killer666
Reply #5 on:
September 10, 2015, 05:30:27 pm »
I need adapters, without them i'm not able to mount them on the hub
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #6 on:
September 10, 2015, 05:41:38 pm »
Ah, yes... I see now. As said, contact Vagbremtechnic...
All Things Mk5
