Author Topic: 2005 Standard manual GTI - Thermostat query  (Read 3430 times)
Offline ReflexRob
« on: September 18, 2015, 01:09:22 pm »
Afternoon fellas
VW have supplied me with what I believe is the main thermostat for my 2005 manual GTI with AXX engine.
Does this look correct?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vj8fn3gg55c2p8d51e4frabv6t&/topic,90967.msg917089.html#msg917089
Re: 2005 Standard manual GTI - Thermostat query
« Reply #1 on: September 18, 2015, 01:15:26 pm »
That looks correct. I found the front pipe the hardest its a hard line. There are two triple square screws holding it in place once you find these its easy.
05 | Tornado Red | DSG
Offline ReflexRob
« Reply #2 on: September 18, 2015, 02:49:25 pm »
Thank you!
Is there a way to do it without removing the alternator and half the engine?!!!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #3 on: September 18, 2015, 03:05:48 pm »
Thank you!
No the alternator will have to come out. Not that difficult to get out just have a pry bar ready.
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/31-WATER-Replacing_Your_Thermostat/31-WATER-Replacing_Your_Thermostat.htm
Offline ReflexRob
« Reply #4 on: September 18, 2015, 05:06:18 pm »
Thanks - yeah that's the guide I read. Wish it was an easy job!!!
Offline perksy
« Reply #5 on: September 18, 2015, 08:59:56 pm »
Thinking about getting my thermostat done.
What temp should the car run at?  Middle position on the temp gauge is 90 - should it be there?
James
Offline PT82
  • -Given: 19
« Reply #6 on: September 18, 2015, 09:50:56 pm »
Yeah, bang on 90.
Offline perksy
« Reply #7 on: September 18, 2015, 10:27:29 pm »
Then I need a new thermostat!
James
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #8 on: September 18, 2015, 11:53:24 pm »
In case it makes you feel better, I have to do mine too. Fluctuates all over the place.  How much was the genuine thermostat housing?
Instagram: stu_nc88
Offline ReflexRob
« Reply #9 on: September 19, 2015, 07:10:12 pm »
About 45 quid,  not bad but less manufacturing than the dv for the same!
Offline PT82
  • -Given: 19
« Reply #10 on: September 20, 2015, 10:17:17 am »
Going to get mine done aswell. Is this the most up to date part number and suitable for a 2008 car?
06F121111F
