Author Topic: 3dr Rear Speaker Upgrade - Gladen?  (Read 27261 times)
Offline AJP
  • -Given: 392
  • -Receive: 317
« on: October 08, 2015, 10:45:13 pm »
I'm in the process of planning an audio upgrade, and one thing I'm struggling to find info on is the options for aftermarket rear speakers.
I know Gladen do a 3 way kit for the front with an 8" woofer, plug and play with the oem speaker loom etc, which sounds like a decent option, but what about the rear...? Is there even much benefit to upgrading them? (I know a lot of supposed audiophiles claim the soundstage shouldn't be behind you..)
Any pointers?
Offline white91
Re: 3dr Rear Speaker Upgrade - Gladen?
« Reply #1 on: October 08, 2015, 11:53:26 pm »
Gladen are amazing, it's up to you whether you use rear speakers, as long as it's all in phase
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #2 on: October 09, 2015, 07:37:09 am »
Yeah I'm looking at maybe an active sub as an alternative.
The plan was to go for an RCD510, but the more I read the more I hear about crap eq, bass roll-off at volume etc. As much as it'd look nice and oem I'm starting to think an aftermarket hu is what I need to do the speakers justice.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #3 on: October 09, 2015, 08:33:34 am »
You could just put woofers in the rear.
Have a look at this http://www.talkaudio.co.uk/ipb/index.php/topic/374847-teamspb-mkv-r32-build-hr-ultra-lows-19s-sq-biased-install/?hl=%2Bgladen+%2Br32#entry4367406
I have upgraded the front speakers it sounds great with an RNS510 but my sub sounds off as its right in the back of the car. I will be adding just woofers to the rear when i get some cash.
If you are upgrading the front speakers you should deaden the doors.
05 | Tornado Red | DSG
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #4 on: October 09, 2015, 11:39:35 am »
Cheers dazza. I'm actually looking at a Pioneer sub that fits under the passenger seat. It's the ts-wx110a I think. It's active, so quite convenient for a simple budget install.
I'm not arsed about amping up the speakers, but.. does the RCD510 have enough power to do a set of Gladens justice? Think the RCD510 is 4x20w?
Doesn't sound much.
 I've had luck in the past powering 8" comps from an Alpine hu - but that was 4x50w.
Hmmm... I'm unsure about the hu. And I can't find an oem-looking aftermarket one for sensible money.
The RCD510 DAB can be had for less than £200.. but is it worth it..??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: October 09, 2015, 12:02:37 pm »
I think it would be rude not to amp up the Gladens.
I have a side mount sub box. You can have it for £45 delivered if you want (i'm in Spain so wont make much after shipping) i paid £75 currently being sold on ebay for £59.99.
Offline Pashka
« Reply #6 on: October 09, 2015, 12:34:46 pm »
it's for 8 or 10 sub?
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: October 09, 2015, 12:43:31 pm »
Offline xjay1337
  • -Receive: 377
« Reply #8 on: October 09, 2015, 03:19:58 pm »
No point amping up a crap signal. If you want to get the best from your audio change the head unit to an aftermarket one. Plenty of good ones out there.
You don't really notice audio in the rear. For 2 weeks my rears weren't even working and truth be told I didn't notice it until I realised some amp cables weren't plugged in..oops.
So you'd want to buy a 3 way component set for the front (if you have 3 speakers in the front doors already) or otherwise just buy 2 normal component sets.
I have tweeter and 16.5inch front and back in the rocco and it sounds amazing.
in the golf i went from 3 per door front to 2 per door because the Hertz eskl163s didn't fit in the mid position. Audio still improved. Won't notice the mid loss.
In the GTI my mate made me up a tiny flush fit enclosure (because the ones that go into the boot space look w*nk imo) and a Rockford Fosgate shallow mount r2sd4 sub.
Could have done with more sub box space but it sounded pretty good and would still give lots of bass just didn't need it turned all the way up.
Rocco has a 12 inch Pheonix Audio shallow mount which punches pretty well and with the hertz audio all round sounds very good, everyone who gets in likes the audio
have a small problem with clipping at high volumes but the old-ish unknown 4ch hertz amp is probably to blame for that...
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #9 on: October 09, 2015, 04:23:31 pm »
Yeah I'm pretty much at the conclusion that an aftermarket hu is the way to go.
Had a single din alpine in my mk4 with 8" components in the front and I built an mdf shelf with some QB 6x9s (yes I know the old 6x9 parcel shelf thing is frowned upon these days), no amp, and it was a HUGE improvement over stock. I didn't want for much more actually.
The whole setup was quite cheap, and did what I wanted.
Maybe I need to decide a budget and go from there with the mk5.
As much as your setup looks good Jay, I get the feeling it'd be out of my budget, with the amp, false floor etc. I dunno, maybe not.
Could do with finding a good installer near me for a good chat. Anyone recommended around Notts/South Yorks?
Oh and Jay can you recommend any head units that are oem-looking, maybe dab, good sq? Not fussed about nav, bluetooth, phone etc. Something that works really well with a 4th gen ipod nano would be ideal!
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #10 on: October 09, 2015, 04:25:38 pm »
I'll bear that in mind mate, ta for the offer.
Still very much in the planning stage so if a boot sub comes into the equation I'll give you a shout.
Offline xjay1337
  • -Receive: 377
« Reply #11 on: October 11, 2015, 11:48:03 am »
My setup was very cheap. My mate made the sub enclosure. Paid him £60. Sub itself was £85 or something. False floor was all for the air ride and stuff, you don't need something like that.
Amp was just a cheapy MTX Terminator, something like £100. You need an emp to run the sub anyway. A mono amp is very cheap.
If you want to get the most out of the aftermarket speakers then you should look at amping the door speakers as well. I paid £80 for a Hertz 4 ch used amp, not the best but it's OK.
If you do a lot of the work yourself then you'll save money. it's not hard to cut out a false floor really :)
No HU recommendations from me only like what I have used, I'd go for a Pioneer AVH unit, no DAB on that but you can get some higher models that have DAB I think.
The setup on my rocco was a bit more, i didn't pay for jairm to do my false floor as I gave him my evoms intake when I split my GTI (let's say I paid him £200 for arguments sake).
the 12 inch pheonix sub was free as swap for my Rockford Fosgate.
I paid for the wood and sh*te, so about £30 for the wood and materials.
Associated screws etc
2 way Hertz ESKL163 setup would be like £200
I have DSK163 in the back, which were a lot cheaper, around £80 , do want to put ESK in the back later tho.
The 4ch hertz amp was 80 quid as said before
the amp i moved over from the golf (£100)
my kenwood satnav headunit was £300
so that's about £1000 with new sat-nav garmin head unit, all new high end speakers and amps, not too bad!
Offline AJP
  • -Given: 392
  • -Receive: 317
« Reply #12 on: October 11, 2015, 02:34:55 pm »
Very comprehensive info there, much appreciated.
I'm not in a mega-rush to upgrade (may even just plug an ipod kit into the rcd300 to tide me over) so I'll do a good bit of research and then hopefully do the job properly.
That's a great starting point for me, thanks again
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #13 on: October 13, 2015, 01:08:59 am »
TeamSPB sell a quad lock loom converter for 2 or 4 channel amps.
I've orders the Gladen 3 way front speakers and may amp them up at some stage, as well as adding some uprated rear speakers.
#1493
Offline white91
« Reply #14 on: October 13, 2015, 12:02:47 pm »
Which ones did you order? Let us know how you get on
