Author Topic: Rattle on Idle  (Read 5323 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=eg0mqmdm9u7alhpseprg0p95nk&/topic,90967.msg917089.html#msg917089
Rattle on Idle
« on: October 10, 2015, 09:50:33 am »
Another rattle thread sorry.
Don't know where the noise is coming from problem is only does it when in D,R,S if i put it into N or P it stops. Car is idling at about 800. Fuel lines maybe??
05 | Tornado Red | DSG
Offline Vwgtiking
Re: Rattle on Idle
« Reply #1 on: October 11, 2015, 09:10:15 am »
Mines a manual and rattles and squeaks when pulling off or in wrong gear.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #2 on: October 11, 2015, 10:13:08 am »
Mine only rattles when idling.
Where the 2 plastic fuel lines come into the engine bay left side near water expansion tank, give them either a slight push backwards and see if it stops  :wink:
Thanks mate will give it a try.
Offline perksy
Re: Rattle on Idle
« Reply #3 on: October 11, 2015, 10:16:02 pm »
Mine does exactly the same too.  Any idea what causes this anyone?
James
Offline Pesky jones
Re: Rattle on Idle
« Reply #4 on: October 11, 2015, 10:41:35 pm »
James
Pulling off in wrong gear?
Offline Vwgtiking
Rattle on Idle
« Reply #5 on: October 18, 2015, 08:19:05 am »
No. either pulling off or driving in too low a gear.
Offline Vwgtiking
Re: Rattle on Idle
« Reply #6 on: November 20, 2015, 12:50:57 pm »
It's the air box causing this rattley noise
Offline thecremeegg
Re: Rattle on Idle
« Reply #7 on: December 07, 2015, 09:14:36 pm »
I would second this. Had the same problem on the GTI my gf just bought and the line had popped out the clip....20 second fix!
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #8 on: December 09, 2015, 01:28:34 pm »
so i packed the fuel lines as i've seen here.
http://www.golfmkv.com/forums/showthread.php?t=18277
Still got the noise only in drive and foot is fully planted on the brake. Its very noticeable.
Cant see the fuel lines coming into the engine bay think there is a cover over them.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #9 on: December 09, 2015, 02:48:39 pm »
I don't think its the fuel lines too loud.
Here is a vid you can hear it start and stop as i select in and out of drive. (full volume needed)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #10 on: December 09, 2015, 06:59:36 pm »
Could this be down to the DMF?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #11 on: December 10, 2015, 07:27:43 pm »
Still think that's the plastic fuel lines ..try doing what I said under the bonnet , takes seconds fella  :happy2:
Follow the fuel stainless fuel lines on top of engine, and you will see 2 pipes appearing from around the water expansion bottle, one is the feed in pipe, the other the fuel return pipe which goes back to the fuel tank. Just give them a slight push and the noise Will stop. :happy2:
Gave the pipes a push still the same.
Anyone got any other ideas?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Rattle on Idle
« Reply #12 on: December 11, 2015, 11:07:43 am »
Is it worth taking the starter motor off to check the play in the DMF?
