Author Topic: lumpy tickover and fluctuating revs  (Read 2787 times)
Offline njdudsbury
« on: October 16, 2015, 04:12:41 pm »
Seems to run fine. Lumpy tick over and revs raise up then settle again. Any ideas what to check or change?
For info sat in loads of traffic last night, stop start for over an hour. But ran fine after on a 50 mile run
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pbcmsq9h5j3rpn9jf3vvbq3d7i&/topic,19740.0.html
Re: lumpy tickover and fluctuating revs
« Reply #1 on: October 16, 2015, 04:19:01 pm »
Replace the PCV
Offline njdudsbury
« Reply #2 on: October 16, 2015, 05:04:22 pm »
Just done the check with the dipstick. Dont change it much but you get a gush of air?
Offline njdudsbury
« Reply #3 on: October 16, 2015, 05:28:32 pm »
How to guide anywhere on here?
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #4 on: October 16, 2015, 10:47:27 pm »
I have the same issue, even after replacing PCV with latest revision. I'm putting it down to exessive Carbon build up unless there are any other commonly known issues? Replacing the PCV is really simple, a couple of push fit breather hoses and some torx bolts. Takes about 10 minutes if that. It's located at the right hand front of the engine.
Instagram: stu_nc88
Offline Mitch H
  • -Receive: 25
« Reply #5 on: October 16, 2015, 11:39:41 pm »
How much is pcv to buy?
Offline Dave(tm)
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89462.0.html
« Reply #6 on: October 16, 2015, 11:49:36 pm »
About £30.
Dave
Offline DomBacon
« Reply #7 on: October 16, 2015, 11:51:40 pm »
Mines the same at the moment! Tried everything and I'm putting it down to carbon build up!
Offline njdudsbury
« Reply #8 on: October 17, 2015, 08:48:49 am »
All fixed. Pcv changed. Old one still working in a fashion but takes some air to make it pull in. Seems fine now. Thanks
Offline Mitch H
  • -Receive: 25
« Reply #9 on: October 17, 2015, 03:23:17 pm »
Anyone got part number for latest revision of pcv? For my ed30 :)
Offline Pesky jones
« Reply #10 on: October 18, 2015, 12:14:22 pm »
There's a thread around with all the latest revision numbers, pcv, DV cam follower etc. do a search :)
