Author Topic: Air filter  (Read 3121 times)
Offline Gbuck55
Air filter
« on: October 29, 2015, 10:18:45 am »
Can anyone recommend a good air filter please I'm getting the car remapped next week and thought about fitting a new filter I've heard pipercross but then I've also heard k@n  cheers oh it's a mk5 golf gti o5 plate
  • -Receive: 691
Re: Air filter
« Reply #1 on: October 29, 2015, 01:23:51 pm »
I wouldn't bother.  My ED30 makes 340hp with the standard paper filter, the very same one the GTI uses.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air filter
« Reply #2 on: October 29, 2015, 01:28:54 pm »
I went for the ITG/VWR panel filter. :smiley:
I haven't had the chance to check my MAF readings. The car is still with stock map as well.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air filter
« Reply #3 on: October 29, 2015, 01:30:02 pm »
I'm curious to know what my engine will be able to do with the ITG panel filter, as the others mods support a Stage 2+. :smiley:
Offline Gbuck55
Re: Air filter
« Reply #4 on: October 29, 2015, 01:35:59 pm »
Cheers fellas
Re: Air filter
« Reply #5 on: October 29, 2015, 01:37:51 pm »
340bhp with the standard airbox? Sure?
  • -Receive: 691
Re: Air filter
« Reply #6 on: October 29, 2015, 03:13:55 pm »
90% sure.  I say 90% because my clutch started slipping at 310hp.  Had the Helix fitted but not been back yet to get a dyno run to confirm.  My mapper used the same map on mine as he's used on other ED30s with the standard air box, and they all made 330-340hp.
Offline Madone
  • -Receive: 27
Re: Air filter
« Reply #7 on: October 29, 2015, 08:51:43 pm »
I am stage 2+ revo on standard airbox with vwr filter. My tuner allowed me to try a induction before buying, he ran the same revo settings with both and said it would only be right at the top end it would make any diff.
I drove with both.....
Revo intake, not as much low down torque and a more 'woolly' feel to the throttle response. Basically not as crisp low down. But a bit stronger up the top end of the Rev range
Standard airbox, much crisper and stronger everywhere except right at the top end, when I really rang the car out towards the redline if pulled slightly stronger right at the top. But in normal driving, overtaking etc in the midrange the standard airbox was better. I am sure track day lovers would appreciate the top end of the intake. But for road driving it's a no brainer for me.
« Last Edit: October 29, 2015, 08:54:54 pm by Madone »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Air filter
« Reply #8 on: October 29, 2015, 09:15:21 pm »
That's what I want as well. :smiley:
Offline AJP
  • -Given: 392
  • -Receive: 317
Re: Air filter
« Reply #9 on: October 29, 2015, 10:09:42 pm »
You've confirmed a lot of what I've read Madone.
I'm currently just Stage 1 on my GTI and when I go for more I'm sure I'll leave the airbox in place, and just change to a good turbo-back and uprated pump, maybe with a better intercooler if funds allow.
I really don't like the idea of losing that low-mid responsiveness just for the sake of a bit of top end flow.
Offline Madone
  • -Receive: 27
Re: Air filter
« Reply #10 on: October 30, 2015, 09:18:42 am »
My car is a edition 30 so you won't have any issues with the standard box on a normal GTI if I don't at stage 2+ ;)
The other thing for me was the noise, the intake was much louder with way more I cabin noise. That kind of ruined the refined drive you get from a modern hot hatch. You would never know my car has 360+ bhp until you push the pedal. Just how I wanted it. ;)
  • -Receive: 691
Re: Air filter
« Reply #11 on: October 30, 2015, 09:48:13 am »
Yep.  It's what I've found over the years too.
The only people who can get peak efficiency out of the TVFSI is the people who designed and made it - VW.
As you say, any gains in the intake will be right at the top end.  The turbo itself is the mother of all restrictions on a turbo engine, so focus on the exhaust end first.
The only aftermarket filter I've had good luck with and seen tangible results from was a BMC CDA but I'm just not a fan of cotton or foam.  It has nowhere near the same filtration area of the standard paper one, so clog up faster.
