Author Topic: Oil Pressure Warning!  (Read 12119 times)
Offline Greenman
  • Life is not a straight line!
« on: October 30, 2015, 02:56:03 pm »
Hi all.
I got into my 56 GTi yesterday after a few hours drive and as i turned the ignition on the car bleeped at me and i had the 'oil pressure - stop engine' error come up on the dash.  I turned the car off and it went away and the car drove fine.
Is this a common electrical fault on the Mk5's or should i take it to VW for diagnostics?  It hasn't happened again and the car drives fine, loads of oil etc.
I have heard it could be a problem with blocked oil pickup pipes, but as it has gone i'm not sure this is the case for me.
Am i being paranoid?
Cheers,
G.
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Re: Oil Pressure Warning!
« Reply #1 on: October 30, 2015, 03:07:10 pm »
Well it could be the pickup pipe. I presume youve checked the oil level?
Offline Paradox1
  • -Given: 41
« Reply #2 on: October 30, 2015, 05:14:14 pm »
Check the pickup pipe if the oil level is fine.
Its a cheap replacement compared to a new engine- 12-15quid i think.
Drop the sump, 2-3 bolts and replace.
Offline Greenman
« Reply #3 on: October 30, 2015, 06:49:57 pm »
Oil level is fine.
I will check the pick up pipe on the weekend.  Is it easy to get to?
Offline doylebros
« Reply #4 on: October 30, 2015, 07:29:31 pm »
Offline Greenman
« Reply #5 on: October 30, 2015, 08:27:03 pm »
I would read this http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
Cheers, just read that.
If it comes on again i shall seek attention on the oil pick up pipe...:)
Offline Paulo P
« Reply #6 on: October 30, 2015, 09:26:44 pm »
I had the low pressure warning buzzer on my mark 3 GTI and it turned out to be a faulty pressure sensor, at 190,000 miles we suspected that it was a blocked pick up pipe but it was just a cheap sensor in the end and it's still going strong  :jumpmove:
« Reply #7 on: October 30, 2015, 11:20:08 pm »
Will be the oil pick up pipe in the sump
