Author Topic: R-Tech Roller Height - Will i get on the rollers with a -30mm drop?  (Read 4574 times)
Offline Greenman
  • Life is not a straight line!
Hey all.
I have just booked my GTI in at R-TECH to replace my bluefin with a stage1 custom re-map.
The guy on the phone mentioned that it might not get on the rollers if it's lowered with an ED30 Splitter, which worries me as i have work booked in to fit the splitter and eibach pro kit springs later next month (i'm booked in for feb with r-tech).
Has anyone been on their rollers with a 30mm drop and ED30 Splitter? did you get on them ok?
I take it worst case scenario would be i have to remove the splitter.  Is that easy enough to do?
TIA.
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Offline DANBOY66
  • -Given: 41
Re: R-Tech Roller Height - Will i get on the rollers with a -30mm drop?
« Reply #1 on: November 25, 2015, 11:26:45 am »
i reckon you will be fine
it will be tight  :grin:
Dan..
Offline dan930
  • -Receive: 56
« Reply #2 on: November 25, 2015, 12:08:58 pm »
I reckon u be fine mate,my previous car has been lowered & it went on there rollers no problem,my current car has been lowered & went on there rollers no problem
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: November 25, 2015, 12:14:11 pm »
With Eibach Pro-Kit springs you won't have -30 mm lowering, you'll have at best -10 mm compared with a GTI stock suspension which is lowered -20 mm from factory.
This is my GT Sport with Eibach Pro-Kit springs:
This is my Ed. 30 with H&R -30 mm springs (20 mm lower than my GT Sport):
Offline Greenman
« Reply #4 on: November 25, 2015, 01:20:52 pm »
Have you been on r-tech's rollers with both drops?
Eibach say 20mm rear and 30mm front!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: November 25, 2015, 01:32:53 pm »
I'd like to but I'm in Portugal, it's too far away. :laugh:
Eibach says that compared with a normal suspension, not compared with the GTI suspension, like H&R do with their springs. :wink:
I'm sure you'll be fine with Eibach Pro-Kit but don't expect a noticeable drop from standard. :wink:
Offline Greenman
« Reply #6 on: November 25, 2015, 02:04:34 pm »
Ahh i see, thanks for the advise.
I might just stick with the standard springs then and save myself a few bob...:)
Offline dan930
  • -Receive: 56
« Reply #7 on: November 25, 2015, 02:39:07 pm »
My Ed30 was lowered on H&R springs & went on there rollers no problem
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: November 25, 2015, 03:56:32 pm »
From my personal experience you'd still benefit from fitting Eibach Pro-Kits. They're so much better in ride comfort and have less body roll. But if you want better handling you should go for H&R springs or for Eibach Sportlines. I had Eibach Sportlines with stock dampers and I didn't like them. Fitted H&R springs and Koni Sports and now I really like how the car handles. :smiley:
Kam88
« Reply #9 on: November 25, 2015, 04:59:28 pm »
i got ed30 with eibach springs and no problem
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10 on: November 25, 2015, 05:06:23 pm »
Have you tried other suspension setups? My GT Sport with Eibach Pro-Kit, Koni FSD, SALK and the same sway bars of the GTI handled better than my Ed. 30 with Eibach Sportline and OEM dampers. The GT Sport just had more body roll because Pro-Kits are softer than Sportlines. Now my Ed. 30 is much improved and has a better handling (with a SALK and H&R sway bars fitted as well). :smiley:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #11 on: November 25, 2015, 06:24:12 pm »
Hey all.
TIA.
Yes, easily.
I'm on 30mm H&R with an ed30 front and there was plenty of room.
Offline Greenman
« Reply #12 on: November 26, 2015, 09:10:37 am »
Plus i get the extra 10mm drop...;)
I shall see what my wallet is like next year.
Got spraying work, new oil pick up pipe, new cam follower, and a few other things going on next month, let alone exhaust going on this month!
Cheers for the replies all, looks like i will be ok.  Makes me wonder why the r-tech guys thought it would be an issue!
Offline Rob.
« Reply #13 on: November 26, 2015, 08:51:33 pm »
They had me proper stressing when I told them my car was lowered on springs (previous owner), but it worked out fine.
